Out of the carpool lane.
I need to remove the pilot bushing from my crank. How do I do that easily???
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Re: How do I remove a pilot bushing?
Take a chisel and crack the pilot bushing. It will shatter it. Thats the way i do it.
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
Step Brother
If you have an old imput shaft or clutch alignment tool you can fill the hole in the bushing with grease and put the tool in the bushing and keep packing grease in and it gets behind the bushing and pushes the bushing out..George
Always on the hunt...
![]() Join Date: Sep 2006
Hello Brad, I have always had good luck with finding a bolt that will catch just enough threads to tap itself into the bushing at which point when tightened in far enough it will push the bushing right out of the crank. I just used this method on that 67 that you saw in the shop earlier today, its fast and simple. Hope that works for ya, Cb/Mel
#5 | |
Overdrive club
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
i agree that the grease thing works the easiest and the best. my dad showed me how to do it, like was posted above fill the hole in the bushing with grease, then poke the input shaft in and hit it with a hammer. it may take a couple of raps to get it started, and you will have to add more grease as the bushing moves outward. this is the absolute easest method i have tried, and it has the added benefit of not destroying the bushing.
you may have a small amount of grease squeeze back out around the shaft but it won't be much. and no it won't squirt you. hold the shaft with a grease rag to keep it off your hand. once you do it you'll realize how slick that little trick is.
i survived cancer and kidney stones, but my kids are killing me. |
![]() Join Date: Aug 2005
No joke, I have done it this way several times!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
Works for me.Can use alignment tool,also.It`s a hydraulic "un-press"...same principle.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-16-2007 at 08:03 AM. |
I have a snap on light duty slide hammer with a pilot bearing remover attachment. Worked great last week. Harbor freight sells a kit just like mine for about $20 and it works just as well, you can also use the slide hammer for various other jobs.
Step Brother
I keep waitin for someone to show me this work!!! LMAO LMAO
Just because you don't know how to do it dosen't mean it will not work !!! ![]() |
do the no "tools" necessary....use the grease and rod thing.....I use to use bolts or whatever shaft I could come up with that matched the pilot hole size a little grease, and a hammer.....
Just put one in about a month ago..took all of 5 minutes....The best way is to get a pilot bearing remover tool from snap-on or a mac. dealer....its easy ...myself i don't like hammering on the crank ,besides with the motor in the truck there aint a lot of room. You can try them all but in the long run that tool saves a lot of cussing and bleeding knuckles...lots of luck.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
RIP Mr Ron
![]() Join Date: Dec 2005
I go with the slide hammer myself.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
Sleep-Deprived
If the bushing/bearing is stubborn, you can buy/rent the tool at Autozone, Napa, O'Reilly's, etc. Never tried the grease method again after it failed for me years ago - of course it doesn't cost much to try.
Always used the puller along with the biggest allen key that I could fit between the puller legs to keep them from bending and pulling through. I guess Murphy's Law has always applied more to me than the rest of ya'll.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
#15 |
Active Member
![]() Join Date: Jul 2007
The grease in the hole trick never has worked for me. I tried it a couple of times and I would give up with my bad shoulder hurting, banged up knuckles and grease everywhere.
I've always wound up trying alternatives. The bolt in the hole as mentioned by classic Bowties has worked as well as renting or borrowing a pilot removal tool. The problem with buying is that you'll have a tool that you will use only once, maybe twice unless you do mechanical work for a living or if you loan it out to friends. |
#16 |
![]() Join Date: Oct 2006
I take a tap and tap threads into it and keep threading until the bushing comes out. SUPER EASY!
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
