Old 09-20-2007, 10:35 PM   #1
burnitdown612
dana 60 front axle
i was wondering if anyone had a dana 60 front axle .. i got two rear ones but the fronts are just the 10 bolt 1/2 tons with 8 lug axle shafts .. they have 4:10 gears wich are way better than my 3:42s (i wheel the truck so those kinda suck) Also i need a set of 8 lug 15" weels ... i live in wester massachusetts so anybody close to there?
1987 k10 silverado 305/700r4
burnitdown612 is offline   Reply With Quote
Old 09-23-2007, 01:56 PM   #2
bigtruck81
Re: dana 60 front axle
i've had several Dana 60s. my 93 has a HP Ford Dana 60 in the front. the 10 bolt/Dana 44 3/4 ton front should work just fine if you're at 35" tires or under, and can be used for larger tires if you drive sensibly. as for 8 lug 15" wheels, check out www.summitracing.com
bigtruck81 is offline   Reply With Quote
