Old 09-24-2007, 06:41 PM   #1
71Rat
ran out of money
71Rat's Avatar
Drag Racers! what rear suspension you running?
as the title says, for all of you hardcore drag racers to weekend warriors what rear suspension set-up are you running and what times are you turning? pictures would be great also....
thanks
71rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 09-24-2007, 09:42 PM   #2
71Dragtruck
71Dragtruck's Avatar
Re: Drag Racers! what rear suspension you running?
I run a 4-link rear in my truck with coil overs. I've ran a 10.77 with a 1.56 60' at 3975'DA. I had a few 1.52 60' the one weekend and likely would of had a low 10.7 to a high 10.6 with the good air, but was bracket racing with a high dial in and had to get on the brakes hard at the end.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 09-25-2007, 05:20 PM   #3
71Rat
ran out of money
71Rat's Avatar
71dragtruck: looks nice! how long are your bars? also did you c-notch your frame?
anyone else? come on i know more of you race!
Old 09-25-2007, 05:40 PM   #4
71Dragtruck
Bars are about 2 1/2 feet long, it's not c-notched now, but will likely have the frame rails kicked up when I go to a narrowed 9" rear this spring.
Sponsored by:
Hard Candy Customs
Old 09-25-2007, 09:15 PM   #5
fast_dev
fast_dev's Avatar
stock mostly. it actually sounds bad but its working. still got the original bushings in the trailing arms and panhard bar, stock old springs, only change is lakewood drag shocks. 6 lug truck rear with 4:88's and a spool. 1.6 60ft times, 11.91 best in the 1/4, pullin' the left front about 6" every pass. Dev.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 09-25-2007, 09:46 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
Any Pics, of the shocks?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 09-25-2007, 10:24 PM   #7
fast_dev
fast_dev's Avatar
all my pics are at my parents on discs, sorry. i went on a parts website to find the stock length rear shock for our trucks then went on the lakewood site and found the closest thing with eye to eye. however the closest thing was longer so i swapped the shock brackets from left to right which moves the mount lower allowing for the longer shock (some simple mods are required, cut the lip and flatten it, you'll see if you try it) fronts are closest available but were eye to stud, made an eyelet from pipe and took barstock and drilled and tapped it, welded them together = eye to eye. Dev.
Old 09-25-2007, 09:15 PM   #8
djracer
djracer's Avatar
Trailing arms baby! I have been 9.39 @ 133(with only 6 seconds of nitrous)! Looking to go in the eights by the end of the year. My truck has coilover shocks and an antiroll bar. My frame is c notched but its just to make it sit low!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-26-2007, 03:52 PM   #9
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Dont want to hyjack the thread, but is that an Alston anti roll bar? Do you like it, that is to say, would you buy another or go with some other option?
TIA, Tom
Tom Vogel is offline   Reply With Quote
Old 09-25-2007, 09:46 PM   #10
bigjimzlll
bigjimzlll's Avatar
9.70's at 138 in 3500' DA
Burn out video
Click here to watch MOV00769-86
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-25-2007, 11:43 PM   #11
franks72
Junior Member
franks72's Avatar
I've got the stock trailing arms,rancho 9 way adjustable shocks and mickey drag radials .It hooks good now but I'm going to put a looser converter in it and change the 3.73s to 4.10s I'm stuck at 14.00 and its making me nuts ..I hope it will still hook with the new converter and gears........You know as I type this I start to understand how crazy this dragracing makes ya. I'm in the middle of putting together my 69 rs camaro thats going to be a low 9sec street car. And I'm still playing with this truck..crazy.....
franks72 is offline   Reply With Quote
Old 09-26-2007, 03:29 AM   #12
RatPwrd72
RatPwrd72's Avatar
This is a pic of my family's '67 back in 1992 about to leave the line (we are currently restoring it). It has run 10.60 with stock trailing arms (front mount moved down 4 inches), a stock Camaro width 12 bolt and wore out (read:Soft) coil springs, stock shocks, and a 32x14x15 slick.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 09-26-2007, 08:38 AM   #13
djracer
djracer's Avatar
here'a a pic of my setup
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-26-2007, 12:10 PM   #14
nitrofn
no times yet but getting close
nitrofn is offline   Reply With Quote
Old 09-26-2007, 12:18 PM   #15
djracer
djracer's Avatar
Lookin sweet I wish I had a fab housing!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-26-2007, 12:37 PM   #16
sleepyboy
'69 Step
nitrofn..sweet truck..gonna be FUN!!!
It's my truck, and Yes, I CUT the dash, so what??
sleepyboy is offline   Reply With Quote
Old 09-26-2007, 04:09 PM   #17
71Rat
ran out of money
71Rat's Avatar
NICE! looks like stock isnt a bad idea, everyone else who linked it good job!
nitrofn: I cant wait to see the finished truck and hear how it does on the track
djracer: along the lines of tom's question, do you have another shot of your rear to show the antiroll bar and its links better?
Old 09-26-2007, 05:45 PM   #18
Ackattack
Ackattack's Avatar
in my GMC, I am running leaf springs with 1 leaf removed to lower it. Well when I finally got some traction (street tires) it wheel hopped so bad that it completely sheared off one "knob" of a u-joint.
my 68 chevy that I'm shooting for mid 12s in, I'm planning on running trailing arms, hopefully with some type of drag shocks (if I can find some that will work with air bags) as well as a camaro rear sway bar.
Ackattack is offline   Reply With Quote
