![]() Join Date: Aug 2003
bagged ride as a daily driver
how do you like it? what would you do differant. what issues do you encounter? i'm thinking of using the blazer as a daily driver once i get her all bolted up and ready to go again. i only have a 5 mile in town commute and it hardly rains here so that's not a concern.
![]() Join Date: Aug 2005
Re: bagged ride as a daily driver
I drive mine daily. Just need to tuck the exhaust up tighter. I tend to ride as low as possible so there's the occasional scrapage... But the collector flanges are still holdin on
#3 | |
![]() Join Date: Aug 2006
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
#4 | |
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
ive drove mine about 4k miles in around month and half mines a daily driver i dont lay all the way in the frt since we set it up on 17s and im still running my frt inner fenders but once i get 20s were tubing it
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
Look into Accu Air Control System for a daily driver. The system will go to ride height when you start the car. It is based on suspension sensors and not air pressure.
no guages on mine. does fine. had a toyota bagged and bodydropped as a daily but it was on ball valves connected to a gauge so it was real easy to ride at desired height. my bagged ride was stranded once when an airline got loose and my tire rubbed it up till it blew. then i was stuck at home last week because i ran out of nitrogen. lame. but i keep a schrader valve and a few crecent wrenches in my truck in case i run out again.
i came across my install and service manuals for AccuAir today while i was at the shop, and wondered how it would work on something other than a motorhome (what we use them on) apparently they're pretty decent. neat and easy to use systems for sure.
:( BYEBYE :(
just make shure its a quality setup with a good install and dont abuse it and you will be fine
ive put 5k on mine since its been bagged and thats been about 2 months ago
Driven daily here in the great north west
