Old 09-26-2007, 11:56 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Fuel Pump Question
I have a SBC out of a 91 burb, which obviously had a electric fuel pump in the tank. Well I'm putting it in my blazer and am going to use the fuel pump on the block. It's has a plate over it which I took off, but the new pump I got doesn't match up the bolt holes. What am I missing??? I know this is a stupid question but I still need to know
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 09-27-2007, 03:17 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: Fuel Pump Question
Any Pics?, there is a rod the had to be pushed up before the botl holes will line up.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-27-2007, 05:05 AM   #3
cdowns
cdowns's Avatar
vtheres a little metal plat that goes on the block to mount the pump available in plain steel chrome or billet from places like summit speedway motors pepboys etc
Old 09-27-2007, 06:26 AM   #4
brak
brak's Avatar
yup, looks like the block off plate, except it has a hole for the pump arm to pass through.
Example
Mr Gasket p/n 1514 $6.95
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 09-27-2007, 08:52 AM   #5
5150
C10 Club Tennessee
5150's Avatar
Thanks, that looks like it will work.
Bryan
www.gmtruckshow.com
Old 09-27-2007, 09:21 AM   #6
AH619
AH619's Avatar
I Thought That After Gm Went To Throttle Bodies They Didnt Machine A Hole For The Fuel Pump Push Rod To Go Through?
Im Not Even Shure There Is A Cam Lobe To Drive It?
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 09-29-2007, 12:33 AM   #7
brak
brak's Avatar
it depends when the motor was produced. early on they just installed the block off plate and called it done. In the later models they stopped machining the hole.
I pulled a fresh motor from a 89 blazer (TBI, Centerbolt heads) to swap into my camaro, and all i had to do was remove the block off plate, and install the mechanical fuel pump. It worked great.
Old 09-29-2007, 07:52 AM   #8
Boog
laying low
Boog's Avatar
I imagine GM had quite a few blocks with the holes already machined in them to use up once they went with tank mounted pumps. I've heard engines as late as 93 could still have had the holes in them. No problem if one doesn't as you can always plumb in an inline electric one if need be.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-27-2007, 03:42 PM   #9
5150
C10 Club Tennessee
5150's Avatar
There is a rod in there, it was all gummed up and it was a pain to get out. I hope there is or I'm screwed.
Bryan
www.gmtruckshow.com
Old 09-27-2007, 04:47 PM   #10
cdowns
cdowns's Avatar
if theres a rod in there it could be held in place by the bolt at the front of the block// if it is get shorter bolt after fuel pump install
Old 09-27-2007, 06:48 PM   #11
5150
C10 Club Tennessee
5150's Avatar
No, I could tap it back and forth from the cam to the plate.
Bryan
www.gmtruckshow.com
Old 09-27-2007, 08:07 PM   #12
va_tlc
va_tlc's Avatar
if that rod keeps falling down while yr trying to put the fuel pump on, take some sticky grease and coat the rod good and push it all the way up, it wil stay there long enuff to get yr pump on and start yr bolts.good luck
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
