Old 09-28-2007, 05:46 PM   #1
RicksTrucks
RicksTrucks's Avatar
Changing out differential - need advice
I picked up a 3.08 and would like to put it in my 68 Short stepside (350/3 speed on the floor) to see if I can get better mileage and it not get so wound up going down the highway. Had it up on the rack last nite replacing the shocks and noticed the pumpkin was hot after a 30 mile drive. (I know the fluid probably could use a refreshing.)
Is there an easier way to do this rather than exchanging the whole rear end?
Can I just take the stuff out of the pumpkin and if so what are the steps? Advice would be appreciated.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 09-28-2007, 06:07 PM   #2
1969k10stepside
Re: Changing out differential - need advice
You can remove the ring,pinion,and carrier from one and swap it in the other but installing the gears involves being precise and you need the right tools for the job.Anyone with a manual,the correct tools,and the time can do it though but not setting things up perfectly can cause pre-mature and excess wear.
1969k10stepside is offline   Reply With Quote
Old 09-28-2007, 06:11 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
special tools, special know how, Way easier to swap axles.
Old 09-28-2007, 06:15 PM   #4
Classic Bowties
Always on the hunt...
x 2,
Classic Bowties is offline   Reply With Quote
Old 09-28-2007, 06:25 PM   #5
mvfd70
mvfd70's Avatar
yup what they said. I just had the gears replaced in my 72 axle going under my 68. The Pinion was broke on it so I had to replace it anyway. The pinion has to be pressed out and the bearings pressed off. Then new bearings have to be pressed onto the pinion, a new crush sleeve put on, and the pinion pressed back into the pumpkin. Then the yoke has to be tightened to the proper specs so that the pinion turns at the right torque (supposed to use an inch/pounds torque wrench to test that). It was just soooo much easier to let someone with the right tools and way more knowledge than me to rebuild it.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 09-28-2007, 06:59 PM   #6
Ace in the hole
What about pulling the whole assembly off from the front, leaving the pinion, ring gear and all untouched? 10 or 12 bolts holding the whole thing to the axle and swap the whole assembly over. Slide your axles back in and your done, or am I missing something?
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 09-28-2007, 08:19 PM   #7
MT1972cheyenne
MT1972cheyenne's Avatar
The 1/2 ton Chevy rearends don't come apart like that. You have to disassemble the whole setup.
The problem with setting up a used ring & pinion in a different housing is that the have already established a "wear-in" to each other. It is almost impossible to get EXACTLY same position, so usually you end up with early failure. If you have he whole rearend, I'd swap it out.
Its may seem like more work, but it is WAY less technical, even if you were putting in new gears. It's even more difficult to get used gears right on.
MT1972cheyenne is offline   Reply With Quote
Old 09-28-2007, 09:11 PM   #8
Ace in the hole
Ahh, that makes sense now, I am not up on 1/2 ton stuff. I just took apart a 3/4 ton axle with 4.11 gears. Thought I would keep it as a whole to bolt right in, in case I ever want to change my 4.56 out. The downer to this would be I would have to change the front axle gears to match if I want to use my 4wd.
Old 09-29-2007, 01:14 AM   #9
BCOWANWHEELS
3.08 gears and a 3 speed manuel tranny ? 1st gear take offs are gonna be a major clutch slipper. forget hauling loads and pulling a trailer........ if your gonna run the 3.08,s install a sm465 ,4 speed manuel so you,ll get granny first gear to get it moveing....
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
