Old 09-29-2007, 10:27 PM   #1
trailwart
trailwart's Avatar
power steering???
my truck has manual steering in it. 72 3/4ton 4x4 and i want to know what all is needed to convert to power steering. i got laid off from work and im really motivated to get some stuff done to this truck. thanks
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
Old 09-30-2007, 03:13 AM   #2
earl87gta
earl87gta's Avatar
Re: power steering???
All you need is the power steering box of any 4x4 from 69 to 87 and the steering arm and pitman arm. Plus the pump brackets and hoses. And bolt it on its not like the 67 and 68 were there is no indention in the frame for the power steering box.
If you have a big lift on the truck you may want to go to cross over steering if you do that you need a 2wd box instead of the 4wd box and you need a steering arm for the passenger side. It’s a little more work then just regular power steering but it’s the best way to go if its lifted up.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-30-2007, 09:44 AM   #3
trailwart
trailwart's Avatar
ok so it needs to be froma 4x4. i have an old pump from my 87 so i just need the box and pitman and steering arm. thanks
1999 suburban 4x4
Old 09-30-2007, 05:03 PM   #4
Rod
You need to have an aligned pulley set up for the PS pump also....and make sure its correct for the water pump alignment also.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 09-30-2007, 11:57 PM   #5
earl87gta
earl87gta's Avatar
the steering arm and pitman arm that you have may work. post a pic here and Ill let you know if it looks the same. I cant remeber if they were diffrent then or not. for the 67 and 68 Im sure they were but 69 to 72 I cant remeber.
Earl
Old 10-01-2007, 05:56 AM   #6
brak
brak's Avatar
In the FAQ section, there is a really good writeup (by shifty i believe), and it lists part numbers for everything you could possibly need.
as far as mounting the pump, I'm using a PS bracket from march and i really like it. it was simple to install, and mounts completely on the front of the engine. not like the stock brackets that wrap around and mount on the exhaust.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
