newbie first ? which axle pics added
Hey guys I'm new here and just have to say WOW this is a cool place. I am hoping to get started on my 47 5 window soon but for now it is collecting parts, I have my tci weld in front crossmember and air ride triangulated four link for the rear so far, but I need to get a rear end for it. What do you guys suggest the 9 inch or the camaro 10 bolt? Just so you know the plans for the truck are to bag it and make it lay flat on the ground.
Yellow truck club
Re: newbie first ? which axle
Welcome to the board. You will get lots of help and advise from the folks.
We also like pictures of projects. Brian ... ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Apache Club
![]() ![]() My Trucks Apache Sitting Idle MySpace Project Dad's Truck (74 C-10 to K-10 conversion) ![]() |
I think both axles will work fine...I have a 10 bolt from a 2nd gen Camaro
![]() Join Date: Jun 2002
You will have an easier time welding your triangulated 4 link to the 9 inch because of the 1 piece rear housing, also cheaper/ easier to change gears in the 9" because it can be done on the bench. For the above reasons, I suggest the 9"
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
Happy Camper
Pics... we need pics
Welcome aboard from California
RIP El Jay! Love you brother! |
Welcome hope you enjoy your build. Either should work fine if you can find a deal you may consider the Ford 8.8 rear axle it is pretty tough unless you are pushing mega HP. There were a bunch of the Ford 8.8 that came with disk brakes. This is what I used on my project found the rear axle locally for $56. You can check out some photos of the rear axle here. http://www.tagworld.com/azmark
#8 | |
Broke Club =(
who did you go with on the 4-link? |
i'm partial to the ford mainly cause nascar uses a version of them... also my 4 link just clears....
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
thanks for all the info guys I will get some pics up as soon as I can.....mcarrel please tell me where I can get that rear end with the discs already on it that would work for me.
#11 | |
most junk yards will have ford 8.8 rears with discs already on them. most are limited slip and decent gears too.
Lotus Current Rides/Projects 1955.5 Chevy shortbed truck 1952 Chevy Coupe Deluxe car |
#12 | |
Highlow my rear axle came out of a 1986 T-Bird turbo coupe 3:73 gear limited slip it is 59 1/2 inches wide almost exactly the same width as the original. One problem with these is they have 4 bolt lugs bought new hardened axles and adapter plates so I could use common Ford Mustang disk brake parts. Mustang calipers etc are dime a dozen compared to the turbo coupe ones. The place for these parts was http://www.northracecars.com/index.html ask for Richard he is a great guy he helped me thru all of this. Let me know if you need more info. Last edited by mcarrel; 10-02-2007 at 06:08 PM. |
Okay here are the pics of my truck.....need to move it out my gargage and over to the shop so I can start getting some work done
Re: newbie first ? which axle pics added
some more
#15 |
another one
#16 |
I've got a chevy 10 bolt w/ disks, works great, nice width, chevy bolt pattern, from a 3rd gen camaro, '84 I think. But Ford 9 in looks like the sh@t, like a 350 motor, or a MII sus, or a 700r4. I went with the 10 bolt because I had it, but a
Ford 9 in is what I wish I had.
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd 77 FLH |
#17 |
hey stevehsd, my truck came from Hollister. Have alot of family there and we go quite often
#18 |
My entire power train is from my '84 Z/28 that state Farm totlaled. It will even be TPI when I'm done! My 10 bolt will be plenty stong as I never plan to tow. It has disc brakes 'cause the PO of the Z/28 dropped an '87 rear in it with 3:73 and an Auburn posi.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
#19 |
hey is the 59 1/2" measurement for the rear axle outside of drum or inside of backing plates? what would be the best donor vehicle for a perfect fit 9"? I got a guy wanting to do a trade and he is willing to find me the right 9" if I give him some idea what to look for. any help would be great guys
#20 |
You might try 69 to 70 Mustangs
#21 |
Certified Car Nut
I have a 1973 Chevy 8.5 posi 10 bolt with 3:42 gears. A 72-81 gm 8.5 rearend will handle good power just fine. The thing about 9 inch that is desirable is the pumpkin drops out as a unit and the axel are not retained with c-clips (the ford 8.8 does have c-clips). I also think that the Ford 8.8 are lower priced the Chevy big 10 bolt. I brought mine on craigslist for 200 bucks. I believe other the the Grand Nationals Chevy did not use the 8.5 after 82, they used 7.5 rearends.
