Old 10-03-2007, 04:58 AM   #1
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
Turning a C-20 into a K-20
This isnt a build thread and its for a later model chevy but alot of you here seem to have 4x4's so i thought i would ask for your opinions.that being said here goes.
ok my dad has 73 2wd 3/4 ton which has been sitting for the last 5 years.i would like to buy it from him and turn it into a K-20.truck originally came with a 454 and TH400 and if i recall its a cheyenne super so its pretty well loaded well as loaded as you'll get for 73 anyway.truck currently has no motor or trans.my plans are to add a front axle,4 inches of lift,33 or 35 inch tires,unsure on the motor but ill add a 700r4 for better driveability,not sure which tcase to use and the rest will be determined later.so my questions are what would be a good gm front axle to use,which would be the best tcase behind an auto trans,what other situations will i come across in turning a C-20into a K-20.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 10-04-2007, 11:46 AM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Turning a C-20 into a K-20
The problems you are going to run into is you will basically need everything off a 4x4 frame to convert to a 4x2. If you do have the donor 4x4 frame you can swap the body over easier.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-04-2007, 05:57 PM   #3
bigtruck81
agreed, swapping the body will be easier, if only slightly.
bigtruck81 is offline   Reply With Quote
