10-05-2007, 02:11 PM | #1 |
which would you do?
I currently have a ford 8.8 limited slip rear with 3.73 gearing. it is stock with drum brakes.
I can get a 69 camaro rear with aftermarket axles, posi or limited slip... and 4.56 gears for next to nothing. Here is what my concern is... Rear End Ratio: 4.56 @ Desired MPH: 65 Tire Diameter (Height) in Inches: 27 Over Drive Ratio (1 for no OD): .7 RPM at Given MPH: 2582 Rear End Ratio: 4.56 @ Desired MPH: 75 Tire Diameter (Height) in Inches: 27 Over Drive Ratio (1 for no OD): .7 RPM at Given MPH: 2979 It is still under 3k so it seems like it should be ok. right? normally the truck will be an around town cruiser but I will be driving it to the coast and vegas some too. EDIT...part of the appeal of the camaro rear is that it is the same bolt pattern as the front.
Lotus Current Rides/Projects 1955.5 Chevy shortbed truck 1952 Chevy Coupe Deluxe car Last edited by lotussutol; 10-05-2007 at 02:11 PM. |
10-05-2007, 03:46 PM | #2 | |
Re: which would you do?
I thing the 4.56 is way too low gear if you want to make any trips. I would go with the Ford 8.8 w/3.73 that is what I have. Should cruise at a nice RPM on the highway. Talk to Richard at North Race Cars http://northracecars.com/ he can make you new hardened axles for the 8.8 with any bolt pattern you want I think it was about $150. make sure the width of the axle will work for your application. My project here http://www.tagworld.com/azmark
10-05-2007, 04:57 PM | #3 | |
another guy i know has a brand new rebuilt 8.8 with 4.10 gears, aftermarket axles, rebuild kit, with disc for a few hundred bucks...i may just use my stock 8.8 and save my money.
Lotus Current Rides/Projects 1955.5 Chevy shortbed truck 1952 Chevy Coupe Deluxe car |
10-05-2007, 05:17 PM | #4 | |
I also almost went with the Ford Exploder rear axle (they are the right widthmany with disk) but I found out the pinion is off set by like 2 1/2 I didn't like that. May work ok but I wanted the pinion centered. Good luck finding what you need.
10-05-2007, 05:48 PM | #5 |
yeah i have heard of people buying two and combining them...they end up with a shortened and wider rear. wonder if it really works.
10-08-2007, 10:59 AM | #6 |
polishing a turd
just have a machine shop redrill your ford axles for the chevy pattern and press in new studs
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
10-08-2007, 11:15 AM | #7 |
You could get the Camaro rear end and chang the gears to something smaller. It will have the 4 series carrier so I think the smallest gear would be a 4.11. It looks like you are using a overdrive transmission so that would also kill some of the gear ratio. If the price is right then a gear swap might be cheaper than buying axles.
Bernie |
