Power steering questions???????
the power steering is in, but it's way to soft as-in to much power assist, Jeg's has a shim kit to reduce the pump pressure for rack & pinion steering, my dad installed it in his 49 and it quit blowin' out seals, but I'm using a stock 72 power box and stock pump, so what i want to know is if which way do I need to adjust the pressure to stiffen the steering?
Re: Power steering questions???????
Its not the preasure that is the problem. Its the reaction rod in the box. There is a torsion spring in the ps box that is designed to give the road feel, if it is weak, too small, or broken, the power steering will fell very easy. I run a hydraulic winch on my Blazer an have upped the preasure from 750 psi to 1800 psi. It made no difference to the power steering feel.
Thanks, looks like I'll tearing into the box.
try adjusting the allen screw on top. It adds more friction and makes it feel a bit stiffer
'72 K5, known as 'the Fox.' |
