Old 10-06-2007, 12:12 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Please Help!!!
Daughter was out in the garage with me last night and some how managed to drop a plastic wire connector in one of the cooling holes in the head...any ideas on how to get it out without removing the intake and head
1971ChevyTruck is offline   Reply With Quote
Old 10-06-2007, 12:32 PM   #2
beautimus
beautimus's Avatar
Re: Please Help!!!
first, are you sure it is a cooling passage?
if its an air intake passage the connector should stop at the valve pocket, unless it meets an open valve.
first thing i would try would be to use a piece of coat hanger wire and make a ball of masking tape on it, sticky side out, and try to pull it out.
the only other idea i can think of is compressed air but i am not sure that would be the way to go. good luck.
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 10-06-2007, 12:57 PM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Please Help!!!
I’m thinking a vacuum cleaner might work. It will need to be an open hole somewhere down line for this to work well ~ (air flow).
I went through this a few weeks ago with my 20 MO son….only it was needle bearings!!!
I ended up pulling the heads back off to check.
Ended up not being any thing in there, but better safe than sorry.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-06-2007, 01:00 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Please Help!!!
First, can you see it? If you can, you'll have to come with some ingenuity.
Sticky substances on coat hangers as beautimus mentioned or some suction device. Maybe a small rubber hose attached to the suction side of a small vacuum cleaner.
68gmsee is offline   Reply With Quote
Old 10-06-2007, 04:11 PM   #5
Spoof
Spoof's Avatar
Re: Please Help!!!
I'm thinkin' compressed air...but also that maybe YOU dropped it.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
