Old 10-03-2002, 05:29 PM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Question Installing a 454 in my 71 4x4
I know you guys have heard and answered this question before, but what are the procedures for dropping in a big block in my 71 swb 4x4? I know one idea is to put a 2-3 inch body lift, but I already have it lifted 5 1/2 sus. so I didn't want to do that. I have also heard that you can take a 73 crossmember and scoot it up on the frame, and take 73 big block mounts and somehow fit those in to keep from notching the firewall. I really do not want to cut the firewall on a cheyenne super, so if anyone out there can get me some tips, I would sure appreciate it. (I have already found the 73 components, just need to hear if it will work or not)
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 10-03-2002, 11:39 PM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Sent this info to Yukon Jack awhile back and he posted it on the message board. I dont know anyone who has done it but it looks like a good alternative to beating on your firewall or having to use a body lift. If you try it be sure to keep us posted.
http://67-72chevytrucks.com/vboard/s...threadid=24915
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 10-04-2002, 12:42 AM   #3
Truck Hippy
Truck Hippy's Avatar
Hey. I did this swap several years ago with a 72' 4x4. I droped in a 454 and it was no sweat, The truck was a automatic (350 turbo) and i didn't have to cut or move anything. I had an HEI in it with no firewall problems. If i remember right, the only thing i did was on the drivers side there are 3 small bolts that come through from the inside of the cab that hold the gas pedel to the firewall. Make sure those don't stick out very far because that is where the valve cover lip will be and motor movement will cause it to hit. Also on the pass side firewall the valve cover lip is very close to. I don't remember if it would rub or not but i did put a small dent just to make sure it didn't rub. This was an A/C truck and every thing worked out fine. Just take it nice and slow and it should work out ok. E-mail me if you need any more info.
Truck Hippy is offline   Reply With Quote
Old 10-04-2002, 04:46 PM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
I just put a 427 in mine. I also added a 700R4 so I knew that I was going to be moving crossmembers. I moved the engine crossmember 2 inches forward. I also used high performance polyurethane motor mounts. The motor fits in there perfect with no interference problems. It sits in the right position so that a factory BB fan shroud also fits well. BTW, I am using a short water pump setup. Good Luck
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 10-04-2002, 11:08 PM   #5
MJN
MJN's Avatar
My brother just put a 454 in his '72 GMC and the best way he was told was to move the engine crossmember ahead one inch. Then everthing else move forward too of course but thats all you have to do. then all the original linkage will lineup and be useable. He can also put both his hands behind his HEI by the firewall. Everything works, and it fit right in.
Old 10-05-2002, 10:52 PM   #6
DaHateTank
Interesting. Ive got a 396 in my Blazer, and I moved the crossmembers forward an inch.
There's no way, I could put an HEI in my truck. I have to remove the rotor, to get the distributor outta the motor....
short Moroso valvecovers nearly hit the firewall.
used the small block mounts, had to trim the small block fan shroud. Moved the clutch bellcrank to line up with pivot ball hole in BBC.
used Hedman engine swap headers, fit pretty well, after a couple of dents, and a small (1/4 inch deep) notch in the framerail.
HTH
-Marty
DaHateTank is offline   Reply With Quote
