10-09-2007, 09:55 PM | #1 |
Can someone help Im new at this game
I have bought a 72 chevy 3/4 ton 4x4 to restore, it needs alot of help Body wise and needs a tranny . I was wondering if this would work. I came across a good 69 2 wheel drive good body,good motor, good tranny, I was wondering if I could swap the stuff off the 69 and put it on the 72 to make a good truck. Will there be alot of modifications to do this? Is this a good Idea or a bad Idea? any help would be appericiated. Thanks
Tone By the way they are both automatics I dont know if that means anything. Last edited by sethook; 10-09-2007 at 09:56 PM. |
10-09-2007, 10:13 PM | #2 |
Re: Can someone help Im new at this game
That sounds like a good idea. For the most part you won't have many modifications. The only differences body wise might be the tranny hump. 4x4's have the tall tranny hump, some 2wd's have a short tranny hump. If the donor cab has a short hump simply cut that one out, and bolt the tall one from the 4x4 in. That shoudl be the only real modification. I am sure you will run into problems as you go, amybe bad cab mounts or rusty bolts and such but nothing will be majorly different with the body.
Is the 69 a Chevy or GMC?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-09-2007, 10:15 PM | #3 |
Chevy also thanks for the quick reply.. I heard the Trannys are shorter in a 2wd is this true? I didnt think they were.
10-10-2007, 10:57 AM | #4 |
Catchy title goes here..
moved to the 67-72 area so you might get some more replies
10-10-2007, 11:03 AM | #5 |
Is this the 4 speed? If so then the trannys will exchange okay.
10-10-2007, 11:06 AM | #6 |
yes a 2wd and 4wd tranies are different. you will still need a tranie
common sense isn't so common anymore |
10-10-2007, 02:30 PM | #7 |
Thanks everyone, Im going to go and pick the truck up today, I think its a good deal.
10-10-2007, 03:07 PM | #8 |
why dont you just fix the good 2wd? or do you need a 4 wheeler?
10-10-2007, 05:51 PM | #9 |
My son wants a 4x4.
Well we went and picked it up I think it looks pretty good I will try and get some pics up soon |
10-10-2007, 09:31 PM | #10 |
its all about the +6 inches
the tranny won't work, but you can sell off left over 2 wheel drive stuff to pay for the 4X4 trans.
10-10-2007, 09:43 PM | #11 |
Go For It......
Bob
I BELIEVE IN JOHN 3:16 |
10-10-2007, 10:12 PM | #12 |
I think you can make the tranny work isn't it just a little longer? How about some pics?
10-10-2007, 10:18 PM | #13 |
If the 2wd is a 1/2 ton you will need to use the cab mounts from the 4x4. If it's a c/20 the cab mounts will work. (not that it matters you already have it from the 4x4)Other than the hump your good to go. The small hump will work but it's best to change it. Really I think that auto tranny will work with just a little effort. I was told that it will work if you cut about 2" off of the tail. I got the tip from a tranny guy.
10-11-2007, 01:16 AM | #14 | |
10-11-2007, 01:24 AM | #15 |
KEEP ON TRUCKIN'
Welcome to the site.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
10-11-2007, 07:17 AM | #16 |
A th350 is a th350 is a th350. However a 2wd th350 has "tail" on it and a longer output shaft. To use the 2wd version you need to take the tail off and put that 4wd's output shaft in the tranny. If you're going all that work on the 4x4 tranny, you may as well just rebuild it.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
10-11-2007, 10:23 PM | #17 |
really a guy that rebuilds transmissions told me you can just cut off the back of the trans "tail" he says about 2"
