10-10-2007, 06:21 PM | #1 |
C/K frame difference?
How hard would it be to turn a good ol' 1976 C25 GMC (3/4 ton 2wd) Camper Special into a K25? Are there big differences in frame, crossmembers, oil pans, etc? Or is it a pretty basic swap?
Input! Need input! Thanks all! Sam Last edited by yosemitesamiam; 10-10-2007 at 06:21 PM. |
10-10-2007, 08:57 PM | #2 |
Re: C/K frame difference?
it takes so many parts that it is better to have a donor truck on hand --- but if you have a 4wd donor truck - it would be easier to do a body swap
10-10-2007, 11:22 PM | #3 |
10-11-2007, 12:30 AM | #4 |
There was a thread on here where a guy had a 2WD truck and a 4x4 Blazer. When he was done, he had a 4x4 truck and a 2WD blazer, both fully functional.
10-11-2007, 12:38 AM | #5 |
Yeah, I know it is totally doable, as long as the basic structure, that being the frame, is identical. You just have to first be sure that your front axle mounts are in the right spot, along with the suspension mounts, etc. From there, as long as that is all correct in geometry, it is pretty basic! Bolt up Transfer case, start laying out drivelines.
10-11-2007, 03:22 PM | #6 |
www.73-87chevytrucks.com
The Frame RAILS are the same, the mounting points aren't going to be all there, and you will need every bracket from the 4x4 (including the rear)
If you get a donor 3/4T frame (which you will need for all the parts) it would be MUCH simpler just taking the sheetmetal off and swapping it then putting all the parts on there in my opinion.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 10-11-2007 at 03:22 PM. |
10-11-2007, 04:02 PM | #7 |
like a rock
i attemped this swap and it was NOT possible. I attemped to used a 3/4 ton
4x4 suburban front suspension and a 86 3/4 ton 2wd pickup frame. The frame rails were different. I have tread on here somewhere with pictures. I'll post the link later. Whether this is only 3/4 ton frames or the suburban frame? |
10-12-2007, 02:49 AM | #8 |
odd, several others have done it before...
10-12-2007, 04:22 AM | #9 | |
Wishin' I had more money!
It's entirely possible with the right parts, skills, etc. But as Captkaos said, it's probably easier in the long run to just swap out the body, etc. Why not just either sell the 2wd and buy a 4wd, or just buy another truck? I can't see a project like this being worth the effort really. |
10-12-2007, 11:35 AM | #10 | |
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-12-2007, 12:37 PM | #11 |
like a rock
the cross member from the suburban was not the same height as the frame rail on the pickup and I couldn't not complete swap. I'm sure there may be another cross member. For my instance and with the parts available to me, the swap was not possible. I bet the 1/2 ton 4x4 parts truck i got now would of worked. Check out the first page of my swap to see the differences.
http://67-72chevytrucks.com/vboard/s...d.php?t=222438 |
10-12-2007, 12:58 PM | #12 |
I meant the pieces for the front section. Not the actual frame. As in pieces required to make the frame 4x4...
1/2 and 3/4 Burbs use the same frame rails.
