bbc swap.. Need help.
70 gmc 2wd 350 as of now. I am gonna put a bbc in it. What do i need to do motor/tranny mount wise?
I really want to have all this taken care of before the swap so i dont have to put the swap on hold while i order parts. please help guys. thanks |
Re: bbc swap.. Need help.
bump... I know people have done this swap.
A little help would be highly appreciated. |
I used the tubular engine towers that brothers sells, along with a tubular trans crossmember from 700r4 dot com. You can just scoot the stock cross member back if you want.
There's no mounting drama. Bolts right in/up, easy. Where it gets to be a pain is with all the accessories, etc. The stock 350 rad will have to go, you'll want to put in a 4 core HD radiator. The swap is very straightforward. Last edited by Ozona; 10-11-2007 at 09:32 AM. |
I already have a 4 core radiator. I heard somewherethe engine towers need to be changed? True or not?
Pull a search on the topic.....I did it the hard way the first time....I'm doing it again here in the next couple weeks. I'm NOT gonna be afraid to bash my firewall this time...(I'll probably just cut holes in it and re-weld in some recessed pieces of sheet metal to look good/sound deadener. Should bolt right up...PM me in a week or so and we'll swap helpful hints...
![]() A......
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
I have tryed the search option and have got no straight forward answers out of it.
I am not looking for answers about cooling and what not, i know all that. I am asking about Getting the motor and tranny bolted up. I would like to keep my trann mounted were it is, so i can use my driveshaft i have already. My main concern is the towers that the engine mounts mount to, are they the same between bbc and sbc? Also do i just move the towers to the front two holes on the frame instead of the back to like my sbc is? Thanks for the help so far, hopefull someone can give me afor sure answer on all this other stuff. |
![]() Join Date: Aug 2004
The towers are different, they use the front set of holes. You can use the SBC mounts with washers from underneath. As far as the trans, I don't know...
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Just leave the tranny ALONE.....Bolt the engine to it.....mark any rub/hit areas on firewall......see how close the engine sets in place on existing motor mounts (might be real close).....Move engine mounts accordingly.
On FRANKENSTEIN...I used a cross member from an 80 chevy cause I didn't have the right one for a 69.....I also moved everything forward about 2 inches, changed all my driveshaft lengths.........ETC........ This time I'm gonna just stuff it in...mark what I have to move.....and be done with it. DON'T BE AFRAID TO MAKE YOUR OWN ENGINE MOUNTS.... A........
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 Last edited by DieselEater; 10-12-2007 at 08:02 AM. Reason: add to message... |
