10-11-2007, 04:30 PM | #1 |
I make Models
Window question......
My drivers side window started to get difficult to roll up. It rolls down fine but is getting harder and harder to roll back up......nothing appears to be binding.....is this the window regulator causing this??? Thanks
10-11-2007, 04:34 PM | #2 |
Re: Window question......
take door panel off and spray the crap out of everything regulator tracks and lock linkage then get some white lube and put it on moving parts// after 40years it deservers at least that amount of minimal upkeep
10-11-2007, 09:05 PM | #3 |
i agree with cdowns clean and lube first when i put my doors back togather i had already done this ,driver side was great passenger side rolled down great and about 3/4 of the way up, then it started tilting forward and binding. off to the junkyard i went finding that several of them worked till a little bettter than halfway up then bound ,kept looking till i found one that worked smoothly all the way up , installed it and all is well
common sense isn't so common anymore |
10-11-2007, 10:34 PM | #4 |
"1972 C5"
Same problem, mine are the regulators since lube didn't work too well.
10-12-2007, 12:05 AM | #5 |
I have a radical idea!
Also, check the weather stripping that the window slides against (the one mounted in the backside of the vent window). Sometimes as it deteriorates, the felt bunches up in there causing the same problem.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
10-12-2007, 08:05 AM | #6 |
Old member
If the roller's have come out of the tracks this will cause it to be hard to roll up. I had to get mine back into the track inside the door panel.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-12-2007, 10:09 PM | #7 |
I make Models
Thanks for the replies.....I will try to get it apart this weekend and see if I can figure it out.....truck was restored 2 yrs ago and everything has been fine up to now so I will let you know what I find......
10-11-2007, 10:26 PM | #8 |
I agree with what's been said. but if you can get a wire brush in to the tracks before you lube it to clean it up, it would be a good idea. Remember that there's a track welded to the inside of the door panel above the opening. While you're in there, lubing the door mechanism is a good idea, too.
