10-13-2007, 08:30 AM | #1 |
Wire Routing for Courtesy Light Switch - 72 Blazer
I was recently lurking under my dash and I found evidence indicating the courtesy lights on my 72 Blazer were added on by a previous owner. I'm under the impression that this was a factory option with some trucks, Blazers, and Suburbans.
The wiring appears to have been routed incorrectly. The wires in the cabin go to the switch at the "A" pillar from under the dash. The problem is that the wires were ran through the kick panel vent door openings. This method looks to be the fastest and easiest route to the switch. It is not clean looking and puts the wires at risk of damage. I would like to correct this. When installed properly, what is the correct routing for the courtesy lights to the switch at the door? -John
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 10-13-2007 at 08:31 AM. |
10-13-2007, 10:17 AM | #2 |
Ready for off-road
Re: Wire Routing for Courtesy Light Switch - 72 Blazer
In mine, which I think is the factory install, passes through a rubber grommet right above the vent lever. I'm not sure how you can pass the wire through there without taking a lot apart.
10-13-2007, 01:56 PM | #3 |
^ correct.
The end of the wire should come apart from the switch. Pull the wire through, make up to the switch and install the switch into the door pillar. |
10-13-2007, 09:13 PM | #4 |
Excellent picture. Thanks guys. Who would carry rubber grommets for something like this locally?
Photo Gallery of 1972 K/5 Blazer CST |
10-13-2007, 09:34 PM | #5 |
Oh..never mind....
NAPA should have them. If not they should be able to order them for you.
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat |
10-13-2007, 10:35 PM | #6 |
Ready for off-road
Ace hardware has tons of grommets like those in their specialty part area near the bolt section.
