7 bladed fan
I have a fan off the 350 that was in my truck that is 7 blades, not evenly spaced and the blades are somewhat flexible and rivveted to the center hub vanes. is this a good choice for my truck????
Old member
Re: 7 bladed fan
Do you have A/C in the truck? If so Then no, if not then it's fine. A/C trucks need either the clutch driven fan or electric fans.
This is only my opinion and not to be considered the only choice.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: 7 bladed fan
No A/C , so I guess I'll give it a try. The truck seemed okay with it before I tore itdown 4 years ago. I only drove it a few weeeks after I purchased.
its all about the +6 inches
Re: 7 bladed fan
I would ditch the flex fan. The aftermarket ones are well documented to explode, and GM recalled flex fans for the same reason.
Chevy nut
Re: 7 bladed fan
I wouldnt trust any fan...except for the old steel ones. I had a GM clutch fan break a blade off and go thru my wrist. I was tuning a Holley on one of my old El Caminos. I put my hand on the left front fender up by the core support leaned in and and revved the motor. The blade broke off...hit my wrist and split it open and broke the bone there.
![]() ![]() NEVER! Trust these fans. I could have lost my hand that morning and would have only been 23. I use the old school all steel ones or electric now.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Re: 7 bladed fan
I am starting to think I need to look for something else! It ain't worth it. Who sells a good fan that will pull lotsa air??
Re: 7 bladed fan
Ok, I thought flex fans were the type with the flexible blades (obviously). But the guy above had a clutch type fan fly apart. I thought fans with clutches were NOT flex fans
![]() I have a flex type now, and recently obtained <what I thought was> a non-flex fan, and it has a clutch on it... but it sounds like this is the type that can also blow apart? What do I need to get? |
Re: 7 bladed fan
if it was a true rigid fan, that is a very rare happening.
Your clutch could explode and fly through the floor, but it's HIGHLY unlikely. A rigid clutch fan is pretty dern safe. |
