Old 10-13-2007, 04:02 PM   #1
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
Order Of Putting Truck Back Together
i'll tell you after about 2 years of these parts sitting in the garage ,can anyone give a list of what order they should put the truck back together . i've seen so many nice trucks here ,so i know this has to be a hot topic
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 10-13-2007, 08:31 PM   #2
Dadsredwagon
Dadsredwagon's Avatar
Re: Order Of Putting Truck Back Together
big pimp , ya gonna be at the swap meet at the horse track off of fallbrook this sun?
Dadsredwagon is offline   Reply With Quote
Old 10-13-2007, 11:15 PM   #3
Stepside65
Still Truckless!
Stepside65's Avatar
From what i've heard the first thing to go in should be the radiator support. Then just work your way back from there. If I'm wrong some one will surely correct me. Good luck on your reassembly.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 10-15-2007, 12:17 PM   #4
64GMCHorsepower
Justified!
I've always heard start with the cab, and everything flows with that.....
After all, everything lines up off of the cab, right.....????
my .02...
Chad
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 10-15-2007, 02:04 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
my .02...
Chad
Every build post I've seen, will have the cab on the chassis, followed by the front end, and bed.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-15-2007, 01:52 PM   #6
LILRED66
LILRED66's Avatar
From my personal experience, I set the cab first, however I do not tighten anything. I then follow the list below:
inner fenders
radiator support
outer fenders
grille support
grille assembly
After all of these parts are loosely hung, I check alignment and commence tightening fasteners, starting with:
cab supports
inner fenders
radiator support
inner fenders
outer fenders
grille support
I then install:
hood
doors
cowl extensions
firewall cowl
bed
tailgate
glass
After all the sheet metal is correctly installed, aligned and tightened, I follow with the underhood trim, interior trim and the exterior trim.
I hope this quick synopsis is helpful. There are numerous small tasks along the way, however, this is a broad brushed summary of the process that I have followed with success.
Tony
LILRED66 is offline   Reply With Quote
Old 10-15-2007, 07:27 PM   #7
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
inner fenders
radiator support
outer fenders
grille support
grille assembly
cab supports
inner fenders
radiator support
inner fenders
outer fenders
grille support
I then install:
hood
doors
cowl extensions
firewall cowl
bed
tailgate
glass
Tony
thanks tony just what i was hoping for . you the man
EAST
Old 10-15-2007, 10:54 PM   #8
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Before all the front sheet metal is aligned to the cab, shouldn't you shim the cab to align with the box? From what I have seen of our trucks, the box always fits higher than the cab so everything else usually has to be shimmed to match starting. I'm not suggesting the box should go on first because that would just be a PITA but as far as alignment goes you need to start with the item that fits the tallest.
As far as the doors go, I would think they should be installed before the fenders. They would be adjusted to fit the hole and the fenders aligned to match the front of the door. The other reason you want to put them on before the fenders is because it is tough to get at the hinge bolts with the fenders on.
I'm no expert on the subject but I just went through the assembly on my truck and these 2 issues stuck out in my mind.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
