Old 10-14-2007, 05:11 PM   #1
dan468
dan468's Avatar
Short water pump VS long water pump?
So when is a long water pump used and when is a short? Silly questions I'm sure but my BBC didn't come with accessories and I don't know what bling to outfit it with.
Dan
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 10-14-2007, 06:18 PM   #2
72hotrod
72hotrod's Avatar
Re: Short water pump VS long water pump?
I have the short pump and have 4 inches from the tip of the pump shaft to the face of a 4 core radiator, about 6 inches to the front belt on a double pulley. You might could use a long pump, but things would be crowded inside the shroud, and you would definitely need your bolts to be no longer than necessary. I have electric fans, and there is a lot more room.
72hotrod is offline   Reply With Quote
Old 10-14-2007, 06:45 PM   #3
dan468
dan468's Avatar
why would someone use a long pump?
68 C-10
Build thread
Old 10-14-2007, 07:02 PM   #4
john
member #16
john's Avatar
You buy an engine complete with all the brackets would be one reason. Those P/S A/C alt brackets are expensive. The long pump brackets are easier to find.
john is offline   Reply With Quote
Old 10-14-2007, 07:26 PM   #5
uncle
The long water pump setup also started in 73 for the trucks. Ditto on what John said.
uncle is offline   Reply With Quote
Old 10-14-2007, 07:58 PM   #6
corn
I used a long pump on my 396 because I wanted to tuck the alt & power steering pump in toward the motor tighter. No radiator clearance problems.
corn is offline   Reply With Quote
Old 10-14-2007, 08:09 PM   #7
dan468
dan468's Avatar
wouldn't this make the alt and power pump farther from the motor?
68 C-10
Build thread
Old 10-14-2007, 08:25 PM   #8
corn
Look how close everything tucks on 71Dragtruck's truck in the above pic. You cant do that with a short pump. Your belts would be twice as long...
Old 10-14-2007, 08:30 PM   #9
Boog
laying low
Boog's Avatar
Actually by using the long water pump the alternator and power steering pumps are closer to the water pump and crankshaft pulley thereby using a shorter belt on both.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-15-2007, 11:08 PM   #10
69trk
69trk's Avatar
march serpentine with electric water pump, cost around $600 not including water pump
69trk is offline   Reply With Quote
Old 10-16-2007, 12:52 AM   #11
dan468
dan468's Avatar
out of all the serpentine set ups I have yet to see one with AC? Does anyone have that set up?
68 C-10
Build thread
Old 10-14-2007, 08:18 PM   #12
71Dragtruck
71Dragtruck's Avatar
I ended up with a long cause I had all the brackets and stuff already, then over time ended up with all the March stuff. If I were to do it all at once again, I would have went short and all March acc. or even a electric pump to give me more room for my fans.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 07-12-2009, 12:16 AM   #13
41GMC
I have a 72 truck and due to material on hand have installed a 350 engine with a long water pump. Now I cannot find a lower radiatior hose to fit it. I cannot go back and istall a short pump due to using an aluminum procomp timing cover that is so thick that the short pump will not seat.
Can anyone help me with a manufacturer and part number for a hose that works?
41GMC is offline   Reply With Quote
Old 07-12-2009, 11:25 AM   #14
71stroker
71stroker's Avatar
41GMC- is the hose to long to fit or is the angle on the waterpump outlet wrong? I would try trimming a stock one to fit if possible.
My 72 truck has a short pump on it and the motor in it came from a 78 chevy c-10 with a long pump. My issue is that you cant get to the timing mark with a timing light. With the long pump on it you checked the timing between the pump and the timing chain cover. Now the short pump sits against the cover and I have no way to check the timing. I just set it by ear now. Anyone else have this issue?
1971 K10 1/2 ton short fleetside, 4 in. lift, sm465/np205, 383 waiting to go in.
1972 K10 short fleetside converted to 3/4 ton, 12 in. lift, t.350/np205, sbc 350.
1970 C10 short fleetside, saginaw 3 spd, no motor.
1971 GMC 3/4 ton 2wd suburban parts truck.(gutted)
1970 GMC 1/2 ton 4wd suburban t.350/np205 no motor parts truck.
71stroker is offline   Reply With Quote
Old 05-12-2009, 10:11 AM   #15
Sinister
Between Trucks...
Sinister's Avatar
I had a long water pump on my '72 C-20 with a 350, pretty sure it was original.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-12-2009, 01:01 PM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I stand by what I said, all 67-72 trucks used short setups from the factory. If any truck has long pump stuff on it, it has been converted in the past.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-12-2009, 01:35 PM   #17
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I agree. Many people use the LWP on a BB due to cost of the short brackets.
You can do it but it will be a tight fit.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-12-2009, 08:00 PM   #18
BBGMC
BBGMC's Avatar
Mines Not a Tight fit its got a 2" spacer on the water pump to bring the fan closer to the radiator and its still got enough room to fit another 1" spacer and the power steering Pump and Alternator don't have a tight fit I really think this truck was a factory Long pump or at least the engine cause its all in there with plenty of space
BBGMC is offline   Reply With Quote
Old 07-12-2009, 12:34 PM   #19
41GMC
The stock hose for a short pump is all wrong in angle due to difference in pump inlet location.
Old 07-12-2009, 12:35 PM   #20
41GMC
Actually the short pump is wrong in both bend angles and lengths.
