Old 10-15-2007, 04:28 AM   #1
Aussie_C2o
Aussie_C2o's Avatar
vin decode
Could somebody please decode the vin off my truck. I have tried a few on the net but I'm getting incomplete answers.
CCE242Z124089
Also, as it sits everything is matching, trim tag, SPL and the chassis number. Even found the paper in the back of my seat with all the options on it. How can I find out if I have the original engine in my truck??
Any help appreciated.
www.compheads.com.au
FATGM 1972 C20- 500HP 402BBC, Dropped on 20" Billets
Aussie_C2o is offline   Reply With Quote
Old 10-15-2007, 04:42 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: vin decode
C chevy
C 2 wheel drive
E V-8
2 3/4 ton
4 Cab and bed
2 1972
Z Fremont Californiga build plant
124089 24089th truck off that assembly line at that plant
Old 10-15-2007, 05:19 AM   #3
Aussie_C2o
Aussie_C2o's Avatar
Re: vin decode
your a champ. thanks for that. would you know how i can tell if it matching engine?
Old 10-15-2007, 05:57 AM   #4
brak
brak's Avatar
Re: vin decode
to check the engine, right above the water pump on the passenger side, is a flat spot with numbers stamped into it (you may have to do some scraping).
on that pad, the Large numbers will be the casting code, but there will also be a partial vin stamped there, which you can compare with the trucks vin.
remember, if the motor has been machined at some point, there is a chance have ground down that pad, which will make it impossible to verify for sure.
the casting code on the front and rear of the engine will at least tell you if the engine is the correct year.
good luck
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 10-15-2007, 06:32 AM   #5
Aussie_C2o
Aussie_C2o's Avatar
Re: vin decode
I checked this out today and the stamped number doesn't match. I will post the number tomorrow with the block casting number. I know forsure it is a 402 from the casting number and I am an engine machinist and I've already striped and prepped this engine.
Thnaks
Old 10-15-2007, 07:30 AM   #6
Re: vin decode
If it`s a 402 engine there`s a good chance it would be a`72.
Old 10-15-2007, 03:57 PM   #7
Aussie_C2o
Aussie_C2o's Avatar
Re: vin decode
Yeah, but will the engine number be exatly the same as the vin? I have seen some US blocks with 2 numbers on the deck surface. Tis block only has one. I will take a pic today.
Old 10-15-2007, 05:40 PM   #8
john
member #16
john's Avatar
Re: vin decode
Here is a site to decode suffix numbers. The suffix code stamped on the front of the block will be a two or three letter code such as TKA. That will tell you the year.
http://www.nastyz28.com/decode.html
john is offline   Reply With Quote
