Old 10-19-2007, 05:03 PM   #1
bent
The master of disaster
bent's Avatar
A couple of things
Ok first off is i need to know why my truck engine in the 72 is slowly turning over when hooked up to a booster or another vehicle. It will turn by hand as well but it is a little stiff. Does this mean that it is trying to sieze up on me if so what is the easyest fix with out tearing the engine down.
Also broke into the sb350 from the old 79 truck and the cylnder walls and pistons are clean, almost too clean, look almost new with verry little burn on them. how ever the engine is locked up i have a bit of grime i guess you could call it around the outter edge of the piston aginst the walls like its sitting on the opiston rings. NO IDEA ON WHAT TO DO NOW.
PLEASE HELP.
bent is offline   Reply With Quote
Old 10-19-2007, 10:17 PM   #2
franks72
Junior Member
franks72's Avatar
Re: A couple of things
If you can turn it over by hand I would think you have a starter or battery or ground problem..
On the 79 motor why not pull the pan and pop the pistons out, check the crank, find out whats got her stuck??
franks72 is offline   Reply With Quote
