Old 10-19-2007, 06:58 PM   #1
crawdad
crawdad's Avatar
Question Troublesome Lights
The headlights on my 85 are not working properly. When I turn them on bright, the dims come on. When I turn them on dim they all go out. The PO had unplugged the upper headlights under the hood, and now I know why. What could cause this. I do know that I've got to replace the blinker/dimmer switch on the steering column. It was real stiff and I wound up breaking the stem off when I brought the truck home. Would the blinker/dimmer switch cause this problem? Any suggestions on what to check would be appreciated. Thanks.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 10-19-2007, 07:56 PM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: Troublesome Lights
how much did you pay for this truck... just kidding! lets help this man!
chev74 is offline   Reply With Quote
Old 10-19-2007, 08:14 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I take it this is a 4 light system stacked on top of one another low beams being on top and high beams being on the bottom. The low beam headlights have both high & low beam elements in them while the high beams are a single element lamp. It could be that low beam element in both lamps are fried. But with what you said about the dimmer switch, that might be the cause as well if it's not allowing the low beam circuit to close.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-19-2007, 08:17 PM   #4
DBLSPRT68
DBLSPRT68's Avatar
[QUOTE I do know that I've got to replace the blinker/dimmer switch on the steering column. Would the blinker/dimmer switch cause this problem? [/QUOTE]
I'm 99% sure this will fox it. I had the high beam switch on the floor, and when it went out; low beams fine, high beam no headlights at all. Check the connections at the lights, and replace the switch. Report back to let us know. David
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 10-19-2007, 08:34 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
you can test the lights with a test light if you have power to the tabs that plug onto the lights you know its the bulbs if no power and the ground is good then check the switch is prolly bad
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-20-2007, 08:16 AM   #6
jermasaurus
jermasaurus's Avatar
Not to hijack the thread, or change the subject completely- But when the 4 light system is working correctly, should all 4 lights be on when when switched to brights?
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 10-20-2007, 09:29 AM   #7
old Rusty C10
yes
Bob
I hate cancer!!
