Old 10-20-2007, 02:37 PM   #1
boot85
71 Chevy
TBI factory tach question
I am going to be converting my 71 to TBI and I was wondering it there is a way to use the factory tach. Is there a wire that I can splice into that would give a usable signal to the factory 71 tach?
71 C10
72 C20
62 Chevy II 2DR HT
boot85 is offline   Reply With Quote
Old 10-20-2007, 05:25 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: TBI factory tach question
If you are using the HEI distributor it will hook right to it. The one marked tach.
A spade connection or use the factory connection.
I have a 86 305 HO motor with factory tach.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-20-2007, 06:46 PM   #3
boot85
71 Chevy
I am not going to be using an HEI distributor. I am going to be using the ESC distributor off of an 89 chevy TBI setup. Out of the wires going to the distributor there has to be one with a usable signal.
71 C10
72 C20
62 Chevy II 2DR HT
Old 10-20-2007, 07:27 PM   #4
webbes
should be able to hook in to the coil. I am thinking it is the white wire will try and check it to be sure
yup should be white wire off of coil
what year of tbi?
1970 4X4 LONG BED 350 TPI 700R4
webbes is offline   Reply With Quote
Old 10-20-2007, 07:33 PM   #5
Long68
Yes webbes is correct it is the white wire coming off of the coil.
Long68 is offline   Reply With Quote
Old 10-21-2007, 07:10 AM   #6
boot85
71 Chevy
thanks, when I get there I will try it.
71 C10
72 C20
62 Chevy II 2DR HT
