Old 10-20-2007, 11:51 PM   #1
75gmc454
75gmc454's Avatar
m49 trans option
I have searched the site, and everyone agrees that if you had the smallblock you had the 350 trans. Also I found a post about the asterisk by that option code causing a guy to wonder if that meant that even if you had a 350 motor the truck would have been equipped with the 400 trans. My cheyenne super has that asterisk by the m49 code, but the original engine and trans have been removed.
One thing I do know is that if you had the 400 trans you would have an electronic kickdown on that trans. Where on these trucks was that switch for the kickdown. On my 73 it has a switch on the accelerator for the trans. That should be a guarantee, if you find the switch you had the 400.
I would appreciate one of you guys with an original 400 trans truck letting us know where that switch was placed.
75gmc454 is offline   Reply With Quote
Old 10-21-2007, 12:14 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: m49 trans option
in 71 and 72, the kick down is on the throttle pedal.
I've only seen speculation that the astric means anything at all.
Many small block trucks came with the TH400. In 69 and later, the TH350 was the more common tranny of the 2 when a small block was opted, but still, there were 400's bolted to small blocks too.
Old 10-21-2007, 08:47 AM   #3
I think in`70-back the swithch was on the carb.I had something like that on my`70.Never needed to mess with it,but I figured that was it.
Old 10-21-2007, 10:04 AM   #4
chipflyer
chipflyer's Avatar
I've seen 5 or 6 trucks that had original TH400 and the m49 option on the label with the Asterisk, but like Andy said it's only speculation on what it means. I doubt we will ever know what it really means for sure but since the 350 and 400 used the same code (m49) it is quite possible the asterisk was used to distinguish between the two.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 10-21-2007, 11:26 AM   #5
Longhorn Man
Tim, you are right, I didn't mention that since he is messin with a 71/72 truck.
The 70 and older trucks did in fact have the kick down switch on the carb.
Old 10-21-2007, 11:08 PM   #6
75gmc454
75gmc454's Avatar
Thanks for all of the information. You are all right. I looked at a 70 c30 in the junkyard today, it has the kickdown switch on the carb.
Old 10-21-2007, 11:35 PM   #7
GMCMAX
Active Member
GMCMAX's Avatar
I just looked at pics of the label on the 69, it has the M49 with no asterisk but it is a 400 trans behind a 350, switch is on the carb.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 10-22-2007, 03:18 PM   #8
Longhorn Man
a 69 with the switch in the cab?
You sure that's original?
I've NEVEr seen a cab mounted switch, with a rod actuated throttle.
Old 10-22-2007, 05:07 PM   #9
john
member #16
john's Avatar
Heres the kickdown on the carb.
john is offline   Reply With Quote
Old 10-22-2007, 06:37 PM   #10
Longhorn Man
DOH! I misread that... he said on the carb... I thought he said on the cab.
My fault.
