Old 10-28-2007, 10:20 AM   #1
CheyLadd
Transfer case part question
The fitting for the speedometer cable on the piece that bolts to the rear of my 205 transfer case is a mess and is leaking a bunch of oil. First, what is this part called, and second, anyone know where I can get one? Is this a part I can get at napa? I am assuming I need to replace the whole piece and not just the speedometer input portion. If wrong, please let me know. I haven't torn it apart yet. Thanks. BTW, the truck is a 72 k10 swb.
CheyLadd is offline   Reply With Quote
Old 10-28-2007, 04:07 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: Transfer case part question
I'm not seeing it on this link but go here and give these guys a call http://quad4x4.com/New%20Process%20N...fer%20Case.htm
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-28-2007, 04:18 PM   #3
CheyLadd
I should have pulled it apart before I asked. The prior owner had put a gob of sealant around the fitting. After getting all of that off, I took it apart and it was simply missing an o-ring. Problem fixed. Wish they were all that easy.
Old 11-10-2007, 11:11 AM   #4
SoCal71K20
Sorry for the late reply. Checkout www.norcalbigdawgs.net/Gallery/album49
Anyhow, if that site doesn't come up, you need GM # 326561 Sleeve. Rubber part of sleeve will wear out over time and cause fluid leak at this point. Real easy to change out. Good luck.
SoCal71K20 is offline   Reply With Quote
Old 11-10-2007, 01:27 PM   #5
CheyLadd
Socal. Thanks. I finally get it. I have been trying to seal the speedo cable thinking it was missing something. I will get the part ordered.
