10-28-2007, 10:25 AM | #1 | ||
Carb worth keeping?
My brother gave it to me from his buddies old 80's blazer. Is it worth keeing or should I just toss it? IT loks complete.
10-28-2007, 10:29 AM | #2 |
Chevy nut
Re: Carb worth keeping?
NO! Dont toss that carb! If you dont want it send it to me!!
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
10-28-2007, 10:49 AM | #3 |
Under Construction
clean it up and throw a rebuild kit on it. I ran a comp 750 on my 400 sbc .
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
10-28-2007, 11:16 AM | #4 | ||
So it is pretty good carb? As luck would have it I have a 400 coming to replace the worn our 350. I was dreding putting the Quadrajunk back on to the 400. Anything else I should know about it? Edit: Is it a 750? So I know what kit to buy. How to tell? Noob question but oh well. I don't know
10-28-2007, 12:02 PM | #5 |
I like the old carters......thats what ole Vic Edelbrock copied for his line of carbs.....very easy tuning. They wont get as goo gas milage as the Quadra-puke (larger primary bore) but you do get great drivability. One word of caution....use two thick gaskets and if space allows use a 1 inch WOOD or PLASTIC spacer between carb and intake to prevent hot start problems.
Im gonna slam a 3/4 ton....I may be nuts!!! |
10-28-2007, 12:10 PM | #6 | ||
Explain the hot start problem?
10-28-2007, 12:13 PM | #7 |
Java Mechanic
I love those..
Hot start is when the intake gets hot and casues vapor lock in the carb. A spacer fixes this.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
10-28-2007, 12:18 PM | #8 |
Yes with todays gas being blended more for fuel injection the problem happens more and more....The aluminum of the carb really soaks in the heat and percolates it....no start or hard start.....I have had Carters and Edelbrock's on at least a dozen rides and ALL of the had the problem. My Charger was so bad I finally invested in a custom spacer and 2 THICK gaskets....starts first crank when hot!!
10-28-2007, 12:14 PM | #9 | ||
See in pic (not very well) but it came with a spacer. See bottom right. Will this work?
10-28-2007, 12:19 PM | #10 |
I would use wood or plastic....at least use THICK gaskets
10-28-2007, 12:33 PM | #11 |
Java Mechanic
That adapter plate won't insulate much.
As well as fixing the hot start problem, a 2 inch composit spacer will incresae plenum size. Maybe not what you want if you bog off the line, but nice at higher RPM. If you run real low RPM most of the time you really want a q-jet anyway.
10-28-2007, 12:39 PM | #12 | ||
Well the truck a 68 3/4 ton and is not a racer at all. It is used for pulling the toys (quads and 3 wheeler) camping and occasionally furniture moving etc.. over kill for this truck and that carb combo?
10-28-2007, 12:46 PM | #13 |
Not over kill at all.....I would just run a good short duration cam and a GOOD dual plane intake like the Performer....a spacer and the carb....or send me the Carter and I will send you my Quadra-jet and a Holley 750
