Old 10-28-2007, 12:11 PM   #1
FingerTight
So there I was...
FingerTight's Avatar
Swap out front coils
Hey all, did a search and didn't see anything that covered it, probably a bit of a "stupid question" but here goes.
What is the best plan of attack for swapping out the front coil springs? I took a look under there and it seems like the lower a arm mount (u bolts) at the frame would be a good bet...better than prying apart that ball joint / hub / a arm setup.
Anyone have a quick how to on doing this? Are the springs under any sort of pre load with the front end off the ground?
Thanks in advance
- Rick
1969 C10 LWB, leafs, 350/700R4,
2003 Yukon Denali
FingerTight is offline   Reply With Quote
Old 10-28-2007, 12:32 PM   #2
ridin98ci
ridin98ci's Avatar
Re: Swap out front coils
Remove the shocks, dis connect the sway bar...LOOSEN the bottom ball joint nut....SMACK the spindle w/ a BFH an it comes right apart then lower control arm with jack and the spring should fall right out
Im gonna slam a 3/4 ton....I may be nuts!!!
ridin98ci is offline   Reply With Quote
Old 10-28-2007, 12:36 PM   #3
cdowns
cdowns's Avatar
when replacing front springs it's the right time to replace ball joints too
Old 10-28-2007, 01:18 PM   #4
Joe67
67 is sold
http://67-72chevytrucks.com/vboard/s...d.php?t=263423
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-28-2007, 01:53 PM   #5
FingerTight
So there I was...
Originally Posted by Joe67 View Post
Thanks for the replies all, I'll let ya know how it goes this weekend.
- Rick
2003 Yukon Denali
Old 10-28-2007, 01:50 PM   #6
70GMCer
70GMCer's Avatar
Don't take them U-bolts off. Do the ball joint thing.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-28-2007, 02:19 PM   #7
Joe67
67 is sold
Good luck
Old 10-28-2007, 03:33 PM   #8
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Support the a-arm remove u-bolts, remove shocks, lower jack, install new springs Poof! instant low rider.
I had the same question last week and I got several different responses. I just found this method to be the easiest and least involved.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 10-28-2007, 04:07 PM   #9
FingerTight
So there I was...
Good look'n truck! Thanks for the pics.
I am going the other way (stock BB coils replacing worn out stock SB coils)
No issues put'n those u bolts back in while compressing the spring?
- Rick
2003 Yukon Denali
Old 10-28-2007, 05:17 PM   #10
retodd7711
retodd7711's Avatar
It wqasn't really a big deal. The jack takes all the pressure. I didn't pump the jack all the way tight, so I had a little Wiggle room to play with. the jack stand under the frame takes pressure off the suspension (wheel off the ground)
She can't cook
So forget her.
My old farm truck
Old 10-28-2007, 07:47 PM   #11
VDOG
Grand PooBaa Member
VDOG's Avatar
Are you doing a disc brake install. Not that it matters. I took my spindle off to install disc brakes. I place a jack iunder the lower controll arm and once the spindle was off I lowered the jack down slowly. Spring fell right out. To install I just reversed the process. No spring compressor needed.
The first picture is with the spindle removed with the shock bolt holding it together until I place my jack under the arm.
VDOG is offline   Reply With Quote
Old 10-30-2007, 10:10 AM   #12
Wrenchbender Ret
If you do drop the inner shaft there is a peg in the lower part of the u-clamp that must go in a hole in the shaft. It can be a hassle going back. I always take the lower ball joint loose. Then if the inner shaft bushings are bad you can take the control arm off after you pull the spring. The spring is stout & doesn't expand much. If you are doing this on a car you must use a spring compressor. Those springs just keep growing & growing.
Wrenchbender Ret is offline   Reply With Quote
Old 10-30-2007, 05:54 PM   #13
FingerTight
So there I was...
Thanks all, finished the job yesterday. All in all it took me a couple hours (with an oil and filter change thrown in for good measure). I went the u bolt route, put'n those back on was a bit of a trick. Get'n the arm up there was no big deal (jack under the spring cup), but aligning the shaft where it needed to be after the u bolts were started back on was fun.
I ended up prying between the rear frame cup (for the bar) and the inside of the rear arm pivot ear, pulling the bar back. (see attached image...thanks for the pic VDOG)
Gained an inch and a half at the bumper by going from SB 1/2 tons to BB 1/2 tons, couldn't be more stoked!
- Rick
2003 Yukon Denali
Old 10-31-2007, 01:18 PM   #14
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks all, finished the job yesterday. All in all it took me a couple hours (with an oil and filter change thrown in for good measure). I ended up prying between the rear frame cup (for the bar) and the inside of the rear arm pivot ear, pulling the bar back. (see attached image...thanks for the pic VDOG)
Anytime. Hope you and your family were safe during the fires up there.
Old 10-31-2007, 01:55 PM   #15
FingerTight
So there I was...
Thanks man, it was a mess but we all came out unscathed...including all the San Diego family and friends.
- Rick
2003 Yukon Denali
Old 10-31-2007, 02:05 PM   #16
VDOG
Grand PooBaa Member
VDOG's Avatar
Glad to hear that. If you need more info let me know. Im still finding things I have to fix after lowering the truck.
