10-29-2007, 11:45 AM | #1 |
screamin eagle
under seat sub box up or down
just bought 2 12" subs for under seat installation-should I face them towards the seat or floor
SCREAMIN EAGLE |
10-29-2007, 02:51 PM | #2 |
Re: under seat sub box up or down
It doesn't really matter. If you do face them down, I would recommend having 2" of space between the floor and the bottom of the box to move the air. Most people have them face up though.
Good Luck |
10-29-2007, 04:09 PM | #3 |
Rottenwood Garage Member
Face them up............Ive done it both ways............UP
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
10-31-2007, 05:12 AM | #4 |
It Is What It Is,,,,
isn't it a different tone of base if their down?
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
11-01-2007, 02:36 PM | #5 |
It mostly depends on the style of music you listen to. If you primarily listen to rock, country, etc. then you should face them upwards for smooth response. If you are looking for hard hitting bass for R&B, Pop, etc. then the down firing position will be best. If you aim them upwards be sure to protect the speakers with grill plates, or your rear may bust them. If you choose to go with the down firing position the box should have 2” of clearance towards the rear and 2 ¾" at the front. The angle will result in better sound due to the fact that bass has a sound pattern that disperses across surfaces flat, so the angle will provide more efficient reflection. You will need to invest in sound deading material for your cab and doors for the best sound.
11-09-2007, 01:35 AM | #6 |
2" is far more than neccesary to down fire them. 1/2"-3/4" is plenty.
I dont really agree with the above posters. Downfiring seems to provide a better all around low end sound in tight areas whereas upfiring them makes the stage seem "punchy". Of course, every system is different and things such as box construction play a huge factor. Try both and go with what you like better.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
11-21-2007, 12:22 AM | #7 |
I prefer down fire! Subs need a hard surface to resonate off of!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
11-24-2007, 06:15 PM | #8 |
driving is in my blood
I took my 10" custom fit down firing box out of my 98 after one day. I had a 12" in a behind the seat reg. cab box sitting around so I put that in facing up. It sticks out past the seat but it sounds 200% better.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
12-19-2008, 05:06 PM | #9 |
12-20-2008, 05:42 PM | #10 |
lets see a pic of your box
72 cheyenne super 83 chevy...4x4...454 |
12-22-2008, 11:51 PM | #11 |
12-24-2008, 12:27 PM | #12 |
screamin eagle
they fit under no problem-I did this during the summer so I don't have a picture right now
SCREAMIN EAGLE |
12-26-2008, 11:36 AM | #13 | |
I'd really like to see a picture of what you did! How does it sound?...and did you end up pointing them up or down? |
12-26-2008, 07:26 PM | #14 |
I don't know of any truck you can get 4 cubic feet under the seat.
12-27-2008, 12:20 AM | #15 |
screamin eagle
I put the subs facing up-and I'm very happy.I had a 72 blazer with a big box in the back and the base had a harder kick,but for what it is it sounds really nice.Between the subs and the bostons in the kicker panel It sounds mint.
SCREAMIN EAGLE Last edited by NYC-10; 12-27-2008 at 12:21 AM. |
12-29-2008, 10:52 AM | #16 |
How much cu ft did you end up having in your sub boxes?
Like djracer said, I'm scratching my head trying to figure out a box. I am planning on removing the stock seat brackets and making my own that will give more clearance. I'm planning on the box on the driver's side to extend over to the passenger side, and then the passenger side box will extend up behind the seat where I have a little space beside the gas tank. I think I can barely sqeeze 2 cu ft out of them, but I don't know yet. It looks good on paper...but that's paper. So when you came on here and said that you are going to throw two 12" subwoofers under the seat like nobody's business and just wanted to know if they should be pointed up or down you became my instant hero. So how much space did you end up with in your boxes or or they like free air mounted or something? |
12-29-2008, 08:45 PM | #17 |
screamin eagle
I just built the biggest box I could fit under a stock height seat and divided it in half.I didn't get to technical.If the box is not big enough You can buy a filler (pillow stuffing)that tricks the speaker into thinking the box is bigger.Maybe in two weeks I'll have pics
SCREAMIN EAGLE |
12-30-2008, 12:55 PM | #18 |
Double 6's
Heres a pic of mine, 2 10" Kicker CVT's DOWN firing....wouldnt have it any other way, and I listen to all types of music. And I know its a new body, but same thinking I would imagine...I would say 2' is just about right for spacing. Look at how a sound wave works and it will make more sense...just my .02
02-14-2009, 08:23 PM | #19 | |
00' Z28 ("wifes" car) 92' Mustang w/sbc everything needs a little heart beat 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
12-17-2009, 11:08 AM | #20 |
what are the dimensions on that box? any pics?
1970 c/10 swb (show truck) 1972 custom/10 deluxe 4x4 (restoration pending) 2011 silverado ecsb z71 (daily driver) |
