Old 10-06-2002, 02:49 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Help with power steering pump.
I am trying to fit this power steering pump on my 283. I need a pulley that will drive the pump. It needs to have a groove at 5.00 inch spacing from the face of the block. The two grooves in the picture are at 3.25 and 3.75 so I still need the inner groove (3.25 inch) to run the alternator. I guess if I am using the wrong pump or mount braket that would help to know. Perhaps there is a different pulley for the pump that would work. Any help will be appreciated.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-06-2002, 03:46 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Looks correct to me...except the part where the bullies don't line up.
If memory serves, your crank pully is not correct. My old Longhorn had the original set up, and it had a 2 pc crank pully.
Your alt and pump mounting look to be correct.
Old 10-06-2002, 06:43 PM   #3
stllookn
stllookn's Avatar
Andy, So all I need is an add-on section to my existing pulley? That would be nice. I have seen crank pulleys with like 4 or more grooves which is probably what I need.
Old 10-06-2002, 07:08 PM   #4
Longhorn Man
It's been a while since I messed with the original pullies, (the GMC is set up with the newer pullies) but if memory serves....
Can someone confirm this for me?
Old 10-06-2002, 08:05 PM   #5
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
Yea, everything looks right, except for the crank pulley. It should have 3 grooves if it came with power steering originally. At least mine does..
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 10-06-2002, 08:26 PM   #6
stllookn
stllookn's Avatar
Patrick, I don't think just one groove will work since the power steering pump sits so far out...like another 1-1/4 inches from the second groove! It looks like I need a crank pulley with 4 grooves! Anyway...I probably have the wrong pump or bracket even though they bolt up. Perhaps there is another style of pump pulley that is offset to the rear to line up with the second groove.
Old 10-06-2002, 08:30 PM   #7
stllookn
stllookn's Avatar
If I make a new pump pulley or spend $25 on one, I know the pump will be bad and I will have to start all over...LMAO!
Old 10-06-2002, 08:47 PM   #8
crazy longhorn
Fabricate till you "puke"
I think all you need is 1 more groove......its 2 pcs , like the other longhorn said. the last pulley for the steer pump does set a ways out from the other 2. Its been a while for me also, i have been running later model pump,& accessories. I think if you had air, or add on air the crank had 4 pulleys. good luck crazy longhorn
crazy longhorn is offline   Reply With Quote
Old 10-06-2002, 09:54 PM   #9
Patrick Sullivan
Hmm.. here is a picture of mine.. it is stock as far as I know:
Old 10-06-2002, 10:08 PM   #10
stllookn
stllookn's Avatar
That looks right...it has to sit out a ways...like about 1 inch or so. Thanks...Randy is looking for one for me...but if anyone else has one laying around I will be glad to pay for it...providing Randy does not find one for me.
Old 10-07-2002, 12:04 AM   #11
Longhorn Man
Ok, mine was inactive A/C...that explains the 4th one on my old set up.
Old 10-07-2002, 08:27 AM   #12
toms68cst
toms68cst's Avatar
I had a similar issue when I put a pump on my 327. I hunted the junk yards for days and finally found a pulley with the correct offset on a mid-60's full size car SB with the factory PS set up. Most of the newer SB PS setups are somewhat different. I think Fast has some of pullies sitting around.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 10-07-2002, 02:36 PM   #13
Desert Rat
Desert Rat's Avatar
stllokn,theres a few different crank pulleys the flat one takes the long add on crank pulley,the Impala,Chevelle,early truck takes the short one,i have some Impala pumps and tons of crank pulleys,whatever crank pulley you need i guarantee to have it,cover the shipping and ill give you one.Thanks
Micah
Desert Rat is offline   Reply With Quote
