Old 10-06-2002, 03:53 PM   #1
rin68
rin68's Avatar
New Engine!
After a year of saving and bargain hunting, the 383 is done. It's the first engine I've built from the ground up, so say a prayer for me when it goes on the dyno on the 19th.
Here are the details: 383 small block, Vortec heads with all the necessary mods done(ARP studs, clearanced for the lift, Lunati springs, retainers and keepers), Crower 222/230@.050 .470/.488 hydraulic cam, Crane gold race roller rockers, Holley 670 street avenger, totally redone points dist. with Ignitor II and MSD. The short block is a Scat stroker crank w/Eagle 6" full floating rods, SRP dished pistons w/file fit rings. The whole rotating assembly is internally balanced. Zero decked block gives 9.75:1 compression.
Here's the bare block.
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 10-06-2002, 04:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A question for you...is that a points dizzy on there?
Old 10-06-2002, 04:07 PM   #3
rin68
rin68's Avatar
It was a points dizzy in a former life, its been totally torn down and rebuilt with an Ignitor II ignition and matching coil, MSD cap and rotor. Ran on a machine to give 24 deg at 2800 rpm.
Old 10-06-2002, 04:10 PM   #4
Longhorn Man
With that covered...she looks like she should be a screamer. What power levels are you crossing your fingers for?
Old 10-06-2002, 04:12 PM   #5
rin68
rin68's Avatar
400 hp/425 ft-lb would be great, don't want to be overly optimistic. I'm more scared than anything, it being the first I've totally built myself and all that.
Old 10-06-2002, 05:45 PM   #6
toms68cst
toms68cst's Avatar
Thumbs up
Looking good rin. You can come over to Bismarck and help me rebuild my 327 this winter!
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 10-08-2002, 11:33 AM   #7
rin68
rin68's Avatar
Sounds good Tom. When its back on the road (needs some brake work) I'll head down towards Bismarck and we can go cruising.
Old 10-08-2002, 11:37 AM   #8
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Did you find this rebuild to be more expensive than say a ZZ4 Crate engine or less expensive? A new ZZ4 is around 3 -3500. I have a four bolt main sitting on a stand but felt it would be cheaper to buy than build.
I would like 350 to 400 HP as well.
Thanks and the engine looks great!
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-08-2002, 11:39 AM   #9
rin68
rin68's Avatar
I haven't totaled it all up yet, but it will come out around $3000-3400. That total is with a year of bargain hunting for the parts and includes every last bolt.
Old 10-08-2002, 01:28 PM   #10
nate68
i'm running a cam similar to that cept its comp's xe268 and its 224/230 477/480 with vortec heads on my 406. the idle doesnt have that much lope to it but don't let that fool you, it's more torque than you'll ever need. you best get a posi (if you dont already have some) and slicks (if you take it to the track). i'm planning on taking it to the track this spring. post your times if you drag it.
scoggin dickey did a similar buildup except they used 5.7 rods and an rpm air gap manifold & 1.6 rockers, 9.6:1, carter 625 carb (aka edelbrock performer) and got 407hp@5200rpm 460 ft. lbs. @4000
i dont see why they ran an air gap manifold when it peaked at 5200. the regular performer would lower the torque peak a little which would be nice.
it lists the part numbers if anyone wants to know.
over 400 ft lbs at 2500.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 10-08-2002, 07:05 PM   #11
Low68
Low68's Avatar
Hey nate68, do they have any of that info on the web? I am interested in that. I want to rebuild my 400. Thanks
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 10-08-2002, 09:02 PM   #12
nate68
you could email them and they could prolly tell ya. go to their website www.sdpc2000.com and i think u can get a free catalog. i got all the info out of their catalog. they have alot of tech tips in the catalog which is kind of nice. dart iron eagles there are about the same price as vortecs. i'd get those if i were ever to buy brand new heads.
Old 10-08-2002, 09:54 PM   #13
nroden
nroden's Avatar
Looks like you've been having some fun building it. When it gets in looks like you'll have even more fun. GOOD LUCK
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
