Old 11-01-2007, 11:39 PM   #1
mothertrucker424
mothertrucker424's Avatar
4.3 into a 54
i have a 54 3100 i would like to do a ifs and i have a 1985 s10 with a 4.3 and a 10blt rear its also supercharged i would like to put this set up into my 54 what can i do can i use the rear in the 54? i know that a set of v8 mounts will hold the 4.3?right?i found a universial trans mount but what about front suspension?i would like to retain factory frame?????please help
mothertrucker424 is offline   Reply With Quote
Old 11-02-2007, 12:05 PM   #2
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: 4.3 into a 54
what's wrong with the front suspension? do you want ifs?
it might be easier to swap the body onto the s10 frame, but you said you want to keep the original frame.
is your s10 2wd or 4wd?
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 11-02-2007, 06:40 PM   #3
mothertrucker424
Re: 4.3 into a 54
2wd and i figure body fits frame to well but i want better handling
Old 11-03-2007, 09:02 PM   #4
Lrall
Lrall's Avatar
Re: 4.3 into a 54
i dunno about handling power but the 4wd s10 rear works very well, id suggest swapping the frames, it will give better handling being on the s10 chassis
Lrall is offline   Reply With Quote
