Old 11-02-2007, 04:38 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Fuel Tank ????'s
I got my used gas tank out today and took the air drill out getting all of the crap off of it before I hit it with the black chassis paint. I was just wondering what are the other three outlets coming out of the gas tank for??? Obviously the big one is for fuel to enter, but was just wondering what all the other crap was for.
I know it's a stupid question that I should know, but I don't so help please
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-02-2007, 05:55 PM   #2
Burt4x4
Burt4x4's Avatar
Re: Fuel Tank ????'s
Vents that connect to a tube on the driver's side neer the fender well inside the bed, should be a metal tube standing vertical..don't have a pic handy, maybe someone else does.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 11-02-2007, 07:50 PM   #3
herb101
Used Register
herb101's Avatar
The large is obviously the filler, the medium is the filler vent, the two at the top front corners are vents and the one on the sender is the fuel supply.
Herb
BTW - my toes are toward the front, so the back is at the top of the shot.
herb101 is offline   Reply With Quote
Old 11-02-2007, 11:42 PM   #4
5150
C10 Club Tennessee
5150's Avatar
So, do I even need these other lines??? Obviously need the fuel line but do I need the other three. If so, where to they go? I have a 88-98 fuel door and tube.
Bryan
www.gmtruckshow.com
Old 11-03-2007, 12:08 AM   #5
herb101
Used Register
herb101's Avatar
http://67-72chevytrucks.com/vboard/s...=212828&page=2
Post 31 shows the medium size hose and its route to the filler neck. The other two connect to metal lines that run parallel with the bumper on the driver's side rear. My lines are rusted through there, so I don't yet know where they finally wind up. I would guess a charcoal canister somewhere.
You'll need some kind of vent to be able to fill the tank, as the air has to escape to let the fuel in.
Herb
Old 11-03-2007, 02:29 AM   #6
DURRTY
USMC
DURRTY's Avatar
you need to vent the tank to keep from building pressure. The only one you need to run to the front is the fuel line to the pump. the other 2 for emissions testing i guess
don't know the official reason they are there but i know you don't need them to run up the frame to make the truck work.
so no and yes you don't really need it but you do need to vent it. I would the vent up near the filler hole and vent it there. just to keep it out of harms way.
Semper Fi
DURRTY is offline   Reply With Quote
Old 11-03-2007, 09:42 AM   #7
5150
C10 Club Tennessee
5150's Avatar
Thanks for the link. So in essence I just cap the two lines that I've circled from your pic, correct???
Bryan
www.gmtruckshow.com
Old 11-03-2007, 05:21 PM   #8
meathead95
computer illiterate
meathead95's Avatar
if you cap those 2 lines it will fill slower
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-03-2007, 07:09 PM   #9
bdas70chevy
bdas70chevy's Avatar
can u use one of the two for a return line for fuel injection? if need b?
bdas70chevy is offline   Reply With Quote
Old 11-03-2007, 10:12 PM   #10
5150
C10 Club Tennessee
5150's Avatar
So, just leave them alone without hoses????
Bryan
www.gmtruckshow.com
Old 11-03-2007, 11:13 PM   #11
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
The tank on my 69 doesn't have anything hooked to those. Just a little length of hose on the left side for venting purposes. So yes, you can leave them alone and it should be fine. On my 71, I ran the return into the left side for the fuel injection and capped all the others off. It does fill a little slow, but still works fine.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 11-04-2007, 05:08 PM   #12
jfortner
Both of those on my tank go to a small round cylandar next to the fuel filler; behind a square box cover. Then there is also a third line from that cylandar runs all the way to the front of the truck; but isn't connected to anything?
Just an option?
jfortner is offline   Reply With Quote
Old 11-04-2007, 08:40 PM   #13
red71cheyenne
Back in the sticks
It went to the charcoal canister for emissions. My 69 doesn't even have it and I removed it from the 71. If you don't have emissions testing where you live, don't worry about it.
2011 K1500 Suburban
2014 K1500 Pickup
