Old 11-02-2007, 05:34 PM   #1
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
Carrier Question.
I pulled cover off my 12 bolt to reseal and service it while I had it in the air. After I removed the cover to drain it, I had 3 shims fall out. So, I decided to remove the carrier. Now I can not figure out what kind of carrier it is and what type of clutches and retainer to replace in it. The retainer that came out is one weird looking set-up. Any info will be appriciated. The shims that fell out ended up being guide plates for the clutches. Thanks for the help. The odd ball shim came out of the rightside. Not sure what the deal is with it either.
Does anyone know what type of carrier this is? And what replacement clutches and retainers I could use?
Last edited by westbrookw; 11-03-2007 at 08:21 AM. Reason: Didn't post my question
westbrookw is offline   Reply With Quote
Old 11-02-2007, 06:29 PM   #2
shortbed70
shortbed70's Avatar
Re: Carrier Question.
Sounds like its a good thing you took it apart.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-03-2007, 08:22 AM   #3
westbrookw
westbrookw's Avatar
Bump
Old 11-03-2007, 12:29 PM   #4
westbrookw
westbrookw's Avatar
Is it an Eaton? Just a stab here.
