Old 11-03-2007, 11:29 AM   #1
bighead
Bare SWB Frame $100
I've got to clean up the yard some and need this frame gone. It a swb/coil rear frame with the little bumps for a ps box. It's a little rusty so it needs sandblasting. It also needs a few spots welded or hammered out like where the rear shock bracket is and the holes in the frame horns, etc. $100 come and get it.
bighead is offline   Reply With Quote
Old 11-03-2007, 03:52 PM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Bare SWB Frame $100
Is it a coil spring frame? Are you interested in parting it out? I need the cross member and shock brackets. PM me with your number (I have free long distance).
Harry
My Zip Code 33024
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 11-03-2007, 05:17 PM   #3
bighead
Harry, I can pull those parts from another frame I have if you would like. Is it the shock xmember and upper shock brackets you need?
Old 11-23-2007, 03:55 AM   #4
tin67
have you sold it yet... how far from san antonio
tin67 is offline   Reply With Quote
Old 11-24-2007, 05:06 PM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Is it a roller, or just a frame ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-24-2007, 07:04 PM   #6
bighead
Tin & SB, it's a bare frame and is still available. I'm 5 hours from SA. big
Old 11-25-2007, 08:31 AM   #7
killer71
killer71's Avatar
possible 2 get any picts?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 11-25-2007, 08:53 AM   #8
bighead
Sure but it will be a couple days at least before I'm back out to my shop.
Old 11-25-2007, 09:04 AM   #9
killer71
killer71's Avatar
that's fine...take some picts of the areas that need attention...if ya don't mind...thanks!
R.I.P.
Killer 71
10/26/07
Old 11-25-2007, 09:31 AM   #10
68 short step
was this a orignal SB frame, or cut down longbed?
68 short step is offline   Reply With Quote
Old 11-25-2007, 10:07 AM   #11
bighead
It's not cut. I got it from Hugger here on this board but then plans changed like they do. I'd also trade it for a clean no rust 67 right front fender and inner if that helps or maybe something else I could use on my project.
Old 11-25-2007, 11:28 AM   #12
killer71
killer71's Avatar
well put me and short step officially in line pending picts!
R.I.P.
Killer 71
10/26/07
