Old 11-03-2007, 11:58 AM   #1
mwinchel
4/6 drop
hey every I am new to the 67-72 chevy truck stuff so bare with me. i have a 72 chevy that i am going to be running a big block in. i want to go pretty low and possably run some 20s or 22s. I was looking at the ece 4/6 drop but with the combination for a big block it will be a 3.5/6 drop. I am trying to do this the cheap way and have been to car shows and noticed that the ones i see that are dropped never bought the track bar kit or the shock relocators. can i do the same or should i definently buy that stuff to. they have a kit to make it a 3.5 or 4.5 in the front with a big block. what should i do. if i do the 3.5 drop will the front end sit higher then the back let me know thanks
mwinchel is offline   Reply With Quote
Old 11-03-2007, 01:42 PM   #2
5150
C10 Club Tennessee
5150's Avatar
Re: 4/6 drop
Yes, you need to buy the track bar kit if you are going lower then probably 5 inches in the rear.
You can cut one coil off your front springs and get 2 inches. Get a set of 2 1/2 inch drop spindles and you'll get your 4.5. You should be able to get all of it done for around $500 on the cheap.
I don't think the big block will matter, but I could be wrong. If so just do the spindles and set it down and see what it looks like.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-05-2007, 08:05 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 4/6 drop
Don't skimp on the suspension items as you'll eventually hate to even ride in the truck, and eventually have to spend the money for new parts.
Stick with the kit, and you won't have to look back!
Good luck!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
