Old 11-03-2007, 06:37 PM   #1
Sir Fisher
Sir Fisher's Avatar
Turning radius/ratio
i have a 1970 k20 closed knuckle front end; how can i improve the turning radius or can i?? will the open knuckle front end give better turning radius??
thanks,
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 11-03-2007, 07:53 PM   #2
earl87gta
earl87gta's Avatar
Re: Turning radius/ratio
is the truck lifted up when its turned lock to lock does it hit the stops on the axle?
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-03-2007, 08:51 PM   #3
Sir Fisher
Sir Fisher's Avatar
there's nothing wrong with the mechanics that makes the truck turn (as far as i can tell, but that's not saying much) there's no grinding, no rubbing, nothing i can see or hear. i just think the truck's turning radius is horrible, it needs like 6 lanes to do a "U-turn" and was wondering if there is anything i can do about it.
thanks!!
Old 11-03-2007, 09:03 PM   #4
earl87gta
earl87gta's Avatar
if its turning all the way to the stops on the axle there isnt much you will be able to do. you may be able to turn the stops in some more so that it turns a little more but just make sure if you do it dosnt creat other clearence isues.
Earl
Old 11-04-2007, 10:59 AM   #5
Yukon Jack
Yukon Jack's Avatar
An open knuckle axle will help your turning problem. My 69 has the closed knuckle and with the 35 x 12.5 tires it sure sucks to manuver in a parking lot! I can't tell you how much the open knuckle will help but you would also benefit from updating the axle as you will gain disk brakes!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-06-2007, 10:10 AM   #6
jacobs
jacobs's Avatar
I can personally tell you from experience, IF you adjust out the turn stop bolts, it places much more strain on the axle u-joints. When your wheels are turned sharp and you apply very much torque, the front axles and u-joints are very easy to destroy.
jacobs is offline   Reply With Quote
Old 11-11-2007, 01:28 AM   #7
Americanrider
It's a whole lot tighter, I went to an open knuckle D44 on my 67 and now I can do a single U-turn on a wide 2-lane. You will wonder why you didn't do it sooner.
Americanrider is offline   Reply With Quote
Old 11-11-2007, 11:21 PM   #8
Sir Fisher
Sir Fisher's Avatar
thanks all for all the good info!!
