11-05-2007, 02:00 PM | #1 |
Removing gauge cluster
Well ive gotten this far. Now how do i get the rest of it out.
Its no disgrace being poor. Its just inconvenient. |
11-05-2007, 02:48 PM | #2 |
Re: Removing gauge cluster
You need to reach behind the cluster and un clip the spedo cable and un plug the wiring. Should lift right out then.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
11-05-2007, 02:59 PM | #3 |
be careful!
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
11-05-2007, 05:26 PM | #4 |
how do I unclip the speedo cable
11-05-2007, 05:27 PM | #5 |
yeller
Yup, unclip the speedo cable...then it'll slide out enough for you to unplug the rest of the wires. Be careful when removing it not to break any mounting tabs off.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
11-05-2007, 05:55 PM | #6 | |
Do you just pull back the metal tab? Cause i tried that and it wouldnt move
11-05-2007, 06:54 PM | #7 |
Has a metal tab on the bottom, press it towards the steering wheel while pulling the speedometer cable back and should pull right out. this will let the cluster move out from the dash a little more, allowing you to see the wiring harness conedtor, wich has tabs onthe outside that you sqeeze together and gently rock back and forth till it's free. be patienct and lot of luck. bob
11-05-2007, 07:10 PM | #8 | |
Until Seventy Times Seven
Like the others warned, watch the tabs and the plastic around the perimeter of the cluster. Some areas sit behind the metal dash housing/opening.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 11-05-2007 at 07:13 PM. |
11-05-2007, 08:38 PM | #9 |
What do we get for $10?
Don't forget that there prolly is a twist out light that has a fiber optic cable running to the ashtray that will have to be removed as well.
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ) |
11-06-2007, 12:07 AM | #10 |
oops, boxrodz right, but my head was on the floorboard and my feet were out the window
11-06-2007, 01:27 PM | #11 |
Installing Tach gauge cluster
OK ive gotten it in this far and everything works except the tach which I need your guys help hooking up.
in the pictures theres two sets of wires. I dont know where either goes. would i be able to make connector for one set of wires to hook it up to the distributor? Or do i have to buy one somewhere? Which set of wires goes where?
Its no disgrace being poor. Its just inconvenient. Last edited by 1984Silverado4x4; 11-06-2007 at 01:29 PM. |
11-06-2007, 06:36 PM | #12 |
Re: Removing gauge cluster: Now installing the other one
sorry double post
Its no disgrace being poor. Its just inconvenient. Last edited by 1984Silverado4x4; 11-06-2007 at 06:37 PM. |
