11-07-2007, 05:32 PM | #1 |
www.67HEAVEN.com
Build a 4x4?
Since I'm still becoming mechanically-acquainted with these great old trucks, please help a newbie out with the answers to some of these questions.
1967-72 generation: - if a C10 and a K10 were stripped down to a bare frame, are there any differences? - if yes, what are those differences in the frame? - aside from a transfer case, extra driveshaft, etc., I'm guessing that the K10 got 6-lug wheels, heavier brakes???, beefier springs and shocks???, anti-sway bars???, stronger body mounts (or more of them)???......you get the idea. Who has a list of differences between a C10 and K10? - if a much better frame and body were available as a C10, would it make sense to utilize that frame and body to build a K10 (assuming that this is a complete body-off, non-numbers-matching restoration anyway)? All advice is appreciated.
www.67HEAVEN.com 2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme) 1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme) 1967 Belair 2-door-post (project) 1967 Corvette 427/435 coupe (now 502/502 red road warrior) |
11-07-2007, 05:41 PM | #2 |
Re: Build a 4x4?
the frames are different, but not much. What are you trying to do? 2X or 4X much easier to buy what you want than to change a 2wd into a 4wd, but it could be done.
11-07-2007, 05:42 PM | #3 |
Re: Build a 4x4?
I have a 67 Short fleet 4X4 for sale BTW I see you have one in mind or you want one, LMK.
link:http://67-72chevytrucks.com/vboard/c...ct=1980&cat=12 Last edited by 70rs/ss; 11-07-2007 at 05:44 PM. |
11-07-2007, 06:58 PM | #4 |
Re: Build a 4x4?
K has a different engine crossmember, and leaf spring mounting points which are missing from the C.
Check out DIY4x4.com
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
11-07-2007, 07:04 PM | #5 | ||||
Re: Build a 4x4?
Dustin Last edited by 1969k10stepside; 11-07-2007 at 07:08 PM. |
11-07-2007, 07:30 PM | #6 |
www.67HEAVEN.com
Re: Build a 4x4?
Thanks for the answers.
1969k10stepside, Thanks for the very detailed response. Your advice seems sound to me, so I'll abandon (for now at least) any thoughts of converting a C10 to a K10. So, I guess I'm looking for a K10.
11-16-2007, 09:40 PM | #7 |
Re: Build a 4x4?
How hard would it be to make a 85 k10 frame work? I know the wheelbase is a little different. I am building a 2wd blazer on bags and I might would like to make the 67 into a 4x4 when I build it. I have access to a complete rolling 85 k10 with all suspension.
11-16-2007, 09:52 PM | #8 |
Re: Build a 4x4?
Jkade,pm Mudder.He done his '67 with a newer 4wd frame..It will require shortening the frame most likely,making body mounts,adding a body lift,etc,etc.LWB 67-72 4wd frames are fairly cheap,I'd just buy one of them and shorten it and not deal with other issues.
11-16-2007, 11:10 PM | #9 |
Re: Build a 4x4?
Cab mounts are different.The motor sits back,so the fan shrouds are different.All 4wds had a taller removeable trans tunnel.Only 4spd and big block 2wds had the hi-hump.If you swap a 2wd body onto a 4wd frame(both 67-72),it`s easy to make a 4wd out of a 2wd.Numbers won`t match,as you know.Won`t be worth as much as an original in like condition,but will still sell for decent money.
11-17-2007, 09:19 AM | #10 |
Re: Build a 4x4?
Just thinking ahead, it may never happen but I love 4x4's also. I think a ls1 with a sm465 would be pretty sweet or with a nv4500. Of course it would have to have 4" or 6" of lift. I think it would be cool to have one laying frame and have one in the air.
