11-08-2007, 07:55 PM | #1 |
Wishin' I had more money!
Rear brake problems
When I put my new rear end in the truck, I used the brakes on that one, instead of using my old ones (mine were trashed anyways). We bled the brakes, they worked great, and the next day they didn't work again. So we bled them again, and the very next day they didn't work again.
I've been watching the fluid level, and it's not getting low. There's also no leaks anywhere in the brake system. I was told that it may be possible for air to be getting in the rear lines or bleeders without fluid actually coming out, but I'm not sure how true this could be. The only other thing I can think of, is a bad proportioning valve. But it seems odd that the valve would go bad right when the rear end was put in. Anyone have any ideas? |
11-08-2007, 08:33 PM | #2 |
Robert Olson Transport
Re: Rear brake problems
as a rule of thumb if im going to change the rear i will change the rear hose . i would also if you got the rear out of a junkyard change the cylinders too i mean we are talking about $33 dollars extra, and that is just insurance
are you sure the brake line where you connected the rear together is seated right and there are no kinks in the steel brake lines
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
11-09-2007, 01:28 AM | #3 | |
I'm going to try bleeding it one more time and see how that goes. I may even buy a couple new bleeder screws for the rear, and clean out the threads to make sure air isn't coming back in. |
11-09-2007, 08:51 PM | #4 |
Anyone?
11-09-2007, 10:56 PM | #5 |
__________________ good idea
11-10-2007, 04:40 AM | #6 |
glamoros piece o' lowlife
Do you have a loose fitting somewhere on the lines? I had a similar issue, rear brakes would bleed but as I used them they would soften, turns out one of the fittings in the engine bay wasn't sealing quite right - replace the fitting, all is good.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
