Old 11-11-2007, 12:21 PM   #1
Revin68
Recreational Grease Monkey
Revin68's Avatar
Mounting 12 bolt rear into a '60 PU
The rearend in my '60 1/2ton PU is apparently out of a late 60's PU. While the rearend was also from a coil spring truck, apparently my '60's trailing arms have a wider track and could not mount to the later model pads on the rear. The previous owner solved this by putting a U-bolt over the axle and into the trailing arms then proceeded to weld the U-bolt to the axle housing vigorously. He also partialy cut the old pads off. I have a 12 bolt rear out of a '73 1/2 ton with a rear leafspring. I need to find or make new pads to mount the new rear to the trailing arms. Any suggestions?
Thanks, Robert
Revin68 is offline   Reply With Quote
Old 11-11-2007, 04:08 PM   #2
Captainfab
60-66 Nut
Re: Mounting 12 bolt rear into a '60 PU
First, did you know that your '73 12 bolt is 1.5" wider than the original one in a '60? As for the diff housing to trailing arm pads, CPP has them....just have to weld them on.
Old 11-11-2007, 07:38 PM   #3
62ChevyStep
62ChevyStep's Avatar
yep a bit wider, I used a 72 12 bolt rear cut off the axle perches/pads, ordered new ones (for 3" axle) and welded them on.
I will post some pics later when I can get to them (on another computer)
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 11-11-2007, 10:34 PM   #4
Revin68
Revin68's Avatar
Thanks for the info on the pads. Its a huge help. Thanks again.
Old 11-12-2007, 08:10 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hey Robert...just sent you a PM
I have some info for ya !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-16-2007, 12:39 AM   #6
62ChevyStep
if you need the pads go here:
http://www.nolimit.net/prodinfo.asp?number=CC%2D409
