Old 11-11-2007, 04:27 PM   #1
77GMCSerria
Crazy idea
Would it be possible to bolt a Road Ranger 10 speed or Fuller transmission to a 350 or 454 gas motor? If so how was it done? What adapters would be needed?
77GMCSerria is offline   Reply With Quote
Old 11-11-2007, 04:38 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Crazy idea
I guess anything is possible, but why would you want to? A diesel has a very limited RPM range, with most of the medium to large ones only hittin 2500 RPM... requiring many gears to make the engine of any value on the street.
A gas engine can rev twice that without stressing it too much, so it doesn't need the gears.
Old 11-11-2007, 05:30 PM   #3
billdo
billdo's Avatar
Re: Crazy idea
kind of a crazy concepts at first i was thinking you would need a lot of torque to turn it but its a c10 not a peterbuilt. but they are huge trannys. and i dont know what the benifts would be they are not 10 consecutive gears . high low you would go fatser you would glow slower then a 90 year old many taking a dump in first but i may be all wrong give it a try but i wouldnt waste my time i think what you want is an overdrive unit that would be smart.
billdo is offline   Reply With Quote
Old 11-11-2007, 07:54 PM   #4
john
member #16
john's Avatar
Re: Crazy idea
Most of those roadrangers have a 2" input shaft. Some of the older trannys have a 1 1/2" shaft so you would need a custom built clutch and then the bell housing is waaay too big.
john is offline   Reply With Quote
Old 11-11-2007, 08:03 PM   #5
crazy longhorn
Fabricate till you "puke"
Re: Crazy idea
What....you tryin to upstage the guys in the 6spd club? I agree, those parts are very big/heavy, & not really useable in a gas powered pickup. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-11-2007, 10:11 PM   #6
68C15
blood type; Retumbo
68C15's Avatar
Re: Crazy idea
not to mention the chassis modifactions you would need to hold all that weight. it probably weighs more than the whole truck.
68C15 is offline   Reply With Quote
Old 11-11-2007, 11:10 PM   #7
Tycoon4u
Tooloose
Tycoon4u's Avatar
Re: Crazy idea
You would have to have an engine driven air compressor and tanks to be able to shift the high low spliter.
A legend in my own mind!!!
website: http://www.persmedequip.com/
'68 c10 (current project)
http://67-72chevytrucks.com/vboard/s...ht=cherry+bomb
'04 silverado (better halfs)
'07 wildcat 27rlwb(for sale) http://67-72chevytrucks.com/vboard/c...llinois&cat=17
Tycoon4u is offline   Reply With Quote
Old 11-12-2007, 11:53 PM   #8
GMCMAX
Active Member
GMCMAX's Avatar
Re: Crazy idea
The trans shop that we used to get our rebuilds from had a ten speed in a 3/4 ton shop truck with a 454. The guy told me the flywheel, clutch and bell housing came from something like a C60 with a big block, and he used a small electric compressor and tank mounted in the box of the utility body to run the shifter. The fun part was getting the driveline made up. Don't remember about mounts.......
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 11-13-2007, 02:42 AM   #9
chvtrkman
chvtrkman's Avatar
Re: Crazy idea
I'm with the others that question the "why' of wanting to do this. I think GMCMAX is correct.......the old C-60 trucks had a 427 ( I think) with an 8 spd. (4 low/4 high?)....or was it a 5 spd tranny with a 2 spd diff.? Yeah, I think the latter is correct, but dont hold me to it. I could be wrong. My memory is trying to recall the early 80s when I drove a gas job.I don't know if you could mate a RoadRanger to a gas engine without some serious modifications, if it could be done at all.
69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt"
78 C-10 305 TH350 new (old) daily driver
02 Suburban Z71 a.k.a. the family truckster
99 Silverado 1500 Z71
chvtrkman is offline   Reply With Quote
Old 11-13-2007, 07:43 AM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Crazy idea
I drove a '74 C-60 tandem axle dump that had a 427, a 5-speed main box and a 4-speed auxillary box. Single-speed rear axles. Good thing I was a lot younger person, split shifting was a bear. The auxillary box was non-syncro all the way.
Why not look at a 5-speed gear box, then put a Gear Vendors O/D on that? With the money you're talking about spending, along with the machine work needed, this would be cheaper....and not cheap.
Member Nr. 2770
Old 11-13-2007, 03:23 AM   #11
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Crazy idea
Seems like to much of a hassle to make that work. I guess anything is possible but why do that.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 11-13-2007, 07:29 AM   #12
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Re: Crazy idea
I've seen dump trucks with gas motors and a 10 speed. If that's what you're working on it's o.k. A tree trimmer in my neighborhood has that set-up in his bucket truck.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 11-13-2007, 10:04 AM   #13
Re: Crazy idea
You just don`t need all those split gears in a light truck.Sure,it`s cool to run through them all.But,I`m going with a GearVendors auxilary unit.It can split gears,too.My truck has a Muncie M22 4spd with 4 full gears.I`ll have more gear selection than I`ll ever need,mostly overdrive.
