Old 11-14-2007, 02:23 PM   #1
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Question Broken front drive shaft CV
Whats the best solution for this. Its the second time I have broken the center part of the "CV" on my front driveline. Im talking about the assembly at the transfer case for the front driveline. The U-joints still look OK. Can the "CV" be eliminated? Is it even called a "CV"? Im sure someone makes something better. Thanks.
johnnywagon is offline   Reply With Quote
Old 11-14-2007, 04:52 PM   #2
Blazer1970
Blazer1970's Avatar
Re: Broken front drive shaft CV
It is really called Double Cardan Joint. They are not typically a problem. How have you broken it? Do you have a lift? Is the slip joint in the front shaft in good condition?
Blazer1970 is offline   Reply With Quote
Old 11-14-2007, 07:49 PM   #3
LONGHAIR
Typically these are broken because of binding, either from too much lift or droop when 'wheeling.
LONGHAIR is offline   Reply With Quote
Old 11-15-2007, 06:02 AM   #4
vtblazer
vtblazer's Avatar
Never broke one but upgraded to a 1 ton front shaft last year when I needed another front drive line due to the existing one didn't have a long enough slip in it...guess how I found out.
Surprised to hear your breaking the front shaft that way though, must be all that Spokane sand or something.
vtblazer is offline   Reply With Quote
Old 11-15-2007, 10:06 AM   #5
Burt4x4
Burt4x4's Avatar
I too have never broke that part of my driveline. But I did upgrade my drivelines, got them from HighAngle Driveline here in Cali. I would take a measurement from pinion yoke to T-case yoke and have one made and get the beefest one you can afford with the CV
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 11-15-2007, 10:57 AM   #6
Never seen one break.It`s strange that a u-joint took what that yoke couldn`t.Let`s see the damage.
Old 11-15-2007, 12:37 PM   #7
johnnywagon
Yeah its weird. I hope its just "one of those things". I'm going to rebuild it with regular parts for now. I'll tear it down tonight and post some carnage pix tommorrow.
Old 11-16-2007, 12:19 AM   #8
They strarted using the dbl cadon joint when they "married" the trans and t-case which shortened the front driveshaft.The purpose is they handle a steeper angle.Guys are adding a second one on the other end of the front shaft and on rear shafts when lifting alot,on shorter rigs,and when going with doublers(rear shaft).
Old 11-16-2007, 05:35 AM   #9
vtblazer
vtblazer's Avatar
Yep, what he said.
Rear shaft joint pictured.
Old 11-16-2007, 01:09 PM   #10
johnnywagon
The weld-on yoke (to the driveshaft) failed and took the centering yoke with it. On the picture of the new parts the arrow points to the "cup & pin" on the weld-on yoke that connects to the "ball" on the centering yoke. This is where something went wrong. Hopefully it was just old and fatigued. Both u-joints are perfect and the outside case yoke doesn't have any binding/impact marks.
Old 11-16-2007, 04:56 PM   #11
Blazer1970
Blazer1970's Avatar
I would guess that someone put new u-joints in and did not replace the rest of the worn out parts. That probably led to your failure.
Old 11-16-2007, 06:16 PM   #12
johnnywagon
I did put new HD u-joints in not long ago but seriously...who is going to cut off the driveline welded yoke and replace it if its not broke?
