11-14-2007, 10:29 PM | #1 |
Aftermarket Tach ?
Picked up a tach off a friend. He had it in his 88 Chevy w/a 350 all stock. It worked great. I hook it up to mine, 12V, GND, Neg on Coil, and it doesn't read at all until I rev the engine and then it seems like it's reading too low. Maybe by 750 to 1000 Rpm's. But I may just be misjudging the RPM's. It may read fine. But why doesn't it register at idle. I realize that his 88 is going to be HEI and therefore be higher voltage on the coil but I figured the tach would still work on mine. Oh, number of piston switch is in the correct spot,8 (I have a 307 btw). I know I hooked it up right or I wouldn't have gotten anything.
ANY ideas????????? Last edited by 69C10@16; 11-14-2007 at 10:30 PM. Reason: Typo, stupid me. :) |
11-14-2007, 10:55 PM | #2 |
Re: Aftermarket Tach ?
What brand is it?
11-15-2007, 08:33 PM | #3 |
Honestly, I can't answer that question, though I would love to know for myself. There is an odd emblem in the middles of the face that makes out to an MW. It goes up to 8K RPM. Is a four wire tach:
Green - Neg on Coil Red - 12V + Black - Grnd White - Backlight That is all the info I have on it. Any help would be greatly appreciated! |
11-15-2007, 08:42 PM | #4 |
did you try moving the switch around, i had one that evrey now and then the damn switch would act up and i think it defaulted to 4 banger...
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
11-15-2007, 08:50 PM | #5 |
wouldn't that make it read high?? B/c it's seeing twice the spark for what it thinks is less cylinders? I would think it t o read twice as high. I'll try it later tonight. just to see.
