after market turn signal
i got a add on switch missing the wiring diagram,it looks like brothers part # tsa 7200. it has the 4 way flasher and indicators lights it has seven wires green.brown,red,blue,yellow,black,tan or pink.any help would be great thanks
Re: after market turn signal
well i dont know if it would be the same but i also have an aftermarket turn signal and ill check my wires and see if there the same and write down where they go. ill check tomorrow.
John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Hollister, CA.
![]() Join Date: Sep 2006
I also have an aftermarket turn-signal switch...Mine is a 'Signal-Stat'.
I will check my wires and let you know as well...they might be the same color codes. I tested mine on the bench with a battery-charger and a test light. You have two (+) coming in....constant power (key on)..and brake switch; Four outputs (lights), then the last wire might be a (-) or (+) for the built light (if equipped) I will check it out......
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
