11-20-2007, 12:41 PM | #1 |
Re-building Door Hinges
Is it possible to re-build door hinges with just replacing the pin? both of my doors are sagging and im looking for a fix that doesnt involve spending 40$ a peice on new hinges. any suggestions will be a great help, thanks alot.
Travis |
11-20-2007, 12:47 PM | #2 |
That's right, it's Copper!!
Re: Re-building Door Hinges
The pins with new bushings come in a kit. Very easy to rebuild, I got mine at Early Classic.
11-20-2007, 04:01 PM | #3 |
Sure, but if they are very bad the steel parts can be worn too. This can still be fixed. A little welding can re-new the hole. Don't try to put the new bushings in an egg shaped hole, it will fail again quickly. It really only becomes a problem when the spring/check mechanism gets rusted and bound up. They will wear a flat spot and stick. It is usually easier to replace them at that point.
