Old 11-21-2007, 12:49 PM   #1
DREW67
DREW67's Avatar
Big Block Motor Mounts
I was wonder is there a differents in motor mounts for a big block 67-68 vs 69-72? Any pictures?
Drew
DREW67
DREW67 is offline   Reply With Quote
Old 11-21-2007, 12:58 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Big Block Motor Mounts
67s didn't have big blocks, 68-71 has one style of mount and 72 has another. Pictures are on my other computer or I would post them. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-21-2007, 01:00 PM   #3
66skylarkpost
66skylarkpost's Avatar
67-71 bb mounts had an upper that attached to the motor with a smaller lower piece ,with a frame towers kinda like the small block but had a bigger hole and different sitting . in 72 the big blocks went to the later clam shell motor mounts ,a completly different flater frame tower .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 11-21-2007, 02:07 PM   #4
john
member #16
john's Avatar
Heres a how to on using 73-87 mounts in a 67-72 truck. These mounts are cheap and plentiful.
http://67-72chevytrucks.com/vboard/s...d.php?t=128765
john is offline   Reply With Quote
Old 11-21-2007, 02:13 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I used the early stell frame mounts with 350 rubbers I believe,its been so long since I looked at it. I do know the I got the idea off of herefrom board member tx firefighter I believe..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-21-2007, 07:29 PM   #6
Classic Bowties
Always on the hunt...
Here are pics of the two types of BBC towers that were used in all 68-72 factory 396/402 2wd trucks, the 68-71 type are in the top pic and the 72's are in the bottom pic. Cb
Classic Bowties is offline   Reply With Quote
Old 11-21-2007, 07:38 PM   #7
cruiserman
CSK shows the same motor mount for SBC and BBC. Imagine my surprise when I attempted to replace my 402 mounts. It grew to a horror show when I priced mounts at the GM dealer.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 11-21-2007, 08:55 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
i USED THE 68-71 WITH THE 350 CUSHIONS..
MEMBER #6377
Project "7DEUCE"
Old 11-21-2007, 09:08 PM   #9
69trk
69trk's Avatar
I bought some motor mounts from performance online and they worked perfect. They had no issues with clearance with headers or anything. Also they looked better than stock, they are tubular in design and the polyurethane motor mounts were also available for an additional $50. I want to say that i paid around 150 for the complete set. Goto performanceonline.com.
69trk is offline   Reply With Quote
Old 11-27-2007, 04:46 PM   #10
Chevy Fleetside
Chevy Fleetside's Avatar
Got any pictures of this. I was thinking about ordering some for my 65 and was wondering how low they sat. thanks..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-21-2007, 10:12 PM   #11
qksilver
They work well, a couple of guys around here have used them.
qksilver is offline   Reply With Quote
Old 11-21-2007, 11:07 PM   #12
DREW67
DREW67's Avatar
Thanks Guys for all the help. Do you just use 350 motor mounts with the 68-71 mounts? If I was to use the 72 do I have to modify my frame?
DREW67
Old 11-27-2007, 05:52 PM   #13
Richard Dobson
I have removed a 396 from a 69 GMC which has motor mounts that look like the first picture shown, can I use the motor mounts in my 71 Chevy?
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 11-27-2007, 06:30 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Absolutely. They are the correct mounts for a 71 model too and will bolt in without modification.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-27-2007, 07:23 PM   #15
DREW67
DREW67's Avatar
Today I test fitted the 72 on my 67 and they do not line up right with the top frame rails and holes and then there is a 1/4" gap between bracket and frame rail.
DREW67
Old 11-27-2007, 08:25 PM   #16
Tx Firefighter
It sounds like you might have 73-87 mounts rather than 72 big block mounts. They typically need a spacer between them and the frame rail to make up the gap.
They look extremely similar. Easiest way to differentiate between the two types is to count the number of ribs on them. 72 has one rib. 73+ has 2 ribs.
Old 11-27-2007, 08:39 PM   #17
DREW67
DREW67's Avatar
Here are a few pictures of what I'm talking about. I mounted one the bolts to the cross memeber it is the only one that lined up. This occurs on both sides.
DREW67
Old 11-27-2007, 08:45 PM   #18
Tx Firefighter
They're definitely 72 big block mounts.
It does seem like I read in the past that 67's sometimes needed some slight frame mod to do this since they were never engineered to be factory big blocks. I'm out of my element here though, as I've had 3 big block trucks, a 69, a 70 and now a 72, never a 67 though.
Old 11-27-2007, 11:05 PM   #19
lolife99
67-72 parts collector,…
lolife99's Avatar
Doesn't the top rail need to be trimmed? As in narrowed so the top bolt holes will line up. Also,...if running headers,... you might want to test fit them so you can grind a little frame clearance.
Keith
Convert to disc brakes.
Old 11-27-2007, 11:10 PM   #20
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Tx... I'm pretty sure you are right on that.
