Old 11-21-2007, 06:58 PM   #1
BCOWANWHEELS
Speedo cable needs lubed
hows the best way to get the speedometer cable lubed ? i,ve always pulled the inside cable out of the outside cable housing and used white lithium grease and lubed it good while pushing the inside cable back in. i,ve never done the 67-72 chevy truck cable before and was looking for any tips someone might have. i know i,ll have to pull the gauge cluster away from the dash ( good time to install my tach dash lol ) anyway help is appreciated.
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-21-2007, 07:25 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Speedo cable needs lubed
I bought a metal can of dry graphite, has aball in in it that keeps the solution in suspension, it also has a needle point about 3" long. If you take it off at the speedo, and apply from the top, gravity should do the rest...J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-21-2007, 10:49 PM   #3
BCOWANWHEELS
thanks
Old 11-26-2007, 03:18 PM   #4
arcticspade
Dumb question in response: Will lubing it prevent needle hopping?
arcticspade is offline   Reply With Quote
Old 11-27-2007, 12:37 AM   #5
onetonk5
Cereal Killer
onetonk5's Avatar
I borrowed a tool once from a buddy....you pulled the cable off the trans and screwed it to the tool....then hooked a drill up and spun it while you pumped grease into the tube....cool older GM shop tool.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
