Old 11-23-2007, 08:57 PM   #1
60ratrod
yes, i do
60ratrod's Avatar
i robbed the junk yard blind!!
so today i went out to the local junk yard and came across a 1980 chevy 1 ton. and upon looking at it i found that it had a carter afb carb, edelbrock 2101 intake, and hei dizzy all for $70!!! so my thanksgiving is going to be rather busy...
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 11-23-2007, 09:02 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: i robbed the junk yard blind!!
Originally Posted by 60ratrod View Post
so today i went out to the local junk yard and came across a 1980 chevy 1 ton. and upon looking at it i found that it had a carter afb carb, edelbrock 2101 intake, and hei dizzy. so my thanksgiving is going to be rather busy!!!
Now see, if I had found that truck, I'd be excited about the 1 ton disc brakes and 14 bolt rearend! Great score!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-24-2007, 03:38 AM   #3
60ratrod
yes, i do
60ratrod's Avatar
yeah i was looking at the break booster and asked my buddy that showed up to help me rob it and it didn't look like anything that i had seen and he said "oh yeah, thats a hydrolic break booster". i wonder how hard that would be to rig up to mine. all i got for breaks is power in the ol' leg breaks.
Old 11-24-2007, 07:17 AM   #4
The hydro-boost is a great set-up for big cam motors with poor vacuum.It`s a bolt-in install,AFAIK.You`d want to grab everything including the pump which has an extra port.
Old 11-24-2007, 08:16 AM   #5
60ratrod
yes, i do
60ratrod's Avatar
is there a thread on that one?? i need to replace the booster in my 60 c10. we looked into the vac port and saw the bladder sitting in the bottom of the booster!
Old 11-24-2007, 11:14 PM   #6
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
Yukon Jack Has a write up about hydroboost conversion. Just search for Hydroboost.
I did the swap last year. I used the booster, pump and hoses from an 80 1 ton van.
A few things to watch out for. Your power steering box has flared fittings and the tonner has metric o-ring fittings so either swap the box or make a custom hose from the booster to the steering box. You wiil also have to make a custom length pushrod from the pedal to the booster.
I would do it again in a heart beat, the pedal feels great
Make sure your hoses are in good condition. After my conversion the added presure swelled my original rear hose to the size of a golf ball and looked pretty scary.
1967 K20 400TBI SM465/NP205
posi front, Detroit locker 4.56 rear
ND_guy is offline   Reply With Quote
Old 11-27-2007, 09:13 PM   #7
68K20 x Drill
Nice find!
I got a Doug Nash/US gear overdrive unit for $100. Too bad it is set up for Ford.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-04-2007, 10:48 PM   #8
60ratrod
yes, i do
60ratrod's Avatar
Originally Posted by 68K20 x Drill View Post
Nice find!
what in sam hell is the overdrive thingy-mabober??
Old 12-04-2007, 11:04 PM   #9
68K20 x Drill
It is a 2 speed unit that replaces the transmission tailhousing.
Much like a Gear Vendors except you have to let off to shift.
http://www.usgear.com/dual_range.htm
And a few cars
